Question about HP Computers & Internet
How to repair lcd monitor. hp1940. one hirozontal line( black) and one vertical line ( red ) crossing each other at lower left of the screen.
  • 61 Answers
At times, this might be because of a Video Driver issue also. So, to rectify it, One simple way, is to check it with another monitor if you have one. Connect the Tower(CPU) to the other monitor & check if the display is fine. If not, then its is a problem with the Video Driver & you r monitor is working fine. But if the display is fine on the other monitor, i'm afraid to say that your monitor might have gone bad. you can probably take it to a hardware repair shop nearby.
Hope this was helpful.
Cheers, Have a nice day!!
Posted on Sep 15, 2010
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
There is a black line and see through pink bar on my monitor
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
Apr 12, 2010 | Dell 1702FP UltraSharp 17" TFT LCD...
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Red Vertical lines on 15" Acer LCD Monitor
I think this is most likely a monitor problem. Can you try a different monitor of computer to the monitor? That would help pinpoint the problem. Is it under warranty?
Sep 17, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Thin red vertical line length of screen(right side)
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 20, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
