Question about LG Televison & Video
Hi there I have just purchased a LG LX9500. This is a great TV, wow. But I am experiencing one issue. When subjects are moving or being panned across the picture appears "ribbed" or another way to explain it is the subjects have jaggered or blurry edges. This is not the case when the picture is still or slow moving. This weekend I watched motor sport and the driver nams and their positions were shown at the bottom of the screen whiched moved from right to left. These to were blurry, my old plasma showed these are solid and crisp when moving. I have Sky TV and HD cables. I have a Bose system connected also. Is there a fix. Regards W
Trumotion on or off.. try adjusting the blur and judder setting in the picture menu...
banding is common on this set during panning scenes, but it sound like you are descibing trumotion artifacts.
Posted on Oct 09, 2010
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
I need a manual for a frigidaire REG433MNM-1 oven
Hi Steven, thank you for your post!
Wow! Your range is over a decade old - that's a great lifespan for any cooking appliance! I understand you are seeking an Owner's Guide for your range; however most manufacturers only archive appliance manuals up to ten years. Since it is very difficult to find a manual for this specific model, you could reach out directly to the manufacturer to see if they have any literature available. Alternatively, if you are experiencing any issues with your oven, I would be more than happy to assist you.
Best regards!
Chris
Dec 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
New lg tv plastic burning smell
I would contact the store you purchased it from,,,explain the issue and go from there...
Sep 20, 2017 | LG 42LG50 42 in. LCD HDTV
My phone keeps turning on an off by itself and wont stop. It turns on for about 30 sec then turns off, then repeats.
Wow, looks like its time for an upgrade, but first always do your research on any phone your ready to purchase, I recommend a Blackberry, not so cheap, but great in quality
Apr 27, 2011 | LG Cell Phones
How do you rmove the televison from the right-hand door? without breaking anything?
You should move all funiture to the wall.You should move all subjects to walls. You should put more fragile things on that place where you will not bear the TV. If at you have the big TV that move it in parts or employ workers
Feb 15, 2011 | LG LRSC26980 Refrigerator
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
LG LST-5100P set top box does not display menu with an older ( 1998) tv set. Cant select aspect ratios . All I can do is change channels. Any ideas? Rod
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 22, 2009 | LG LST-4200A DTV Receiver
Every time i take a picture of a moving subject on my fuji s3000 digital camera the subject i have just took does not appear on the frame.or only partly in the frame i have tried on all modes even the...
try this photography technique called panning...
panning is when your shooting a moving object you need to follow that moving object while pressing shutter speed..this technique is the technique photographers to capture moving objects...Have you seen a picture that has a blurry background and focused subject (ex. cyclist) panning is used to create this kinds of pictures...try to search in google or photo sites about Panning
Jul 06, 2009 | Fuji FinePix S3000 Digital Camera
Convergence problem
mostly defective convergence are subject to replace!
Oct 05, 2007 | Mitsubishi WS-55807 TV
Red line
as you said, this is a scan problem, but maybe not from the 'board' itself but maybe the flex cable. sometimes it becomes loose and it makes a bad connection between the panel and the board. if the tv is under waranty: please call LG service customer they are very friendly and thay can give you a reference number that will get you a free repair in an authorized LG service center... anyway thats the way we work around here (qu?bec,canada). let me know
Aug 05, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Televison & Video Logo
507 people viewed this question
