Ahuja ssa-5000em showing over load indication
  • eyunni rajagopalan May 31, 2011
    Which type of cable should I use for line-in recording by a Transcend MP3 player using the output of Ahuja SSa 5000EM? Thanks in advance.
Which of the following is not a valid postulate or theorem for proving triangles congruent? A. SSA B. ASA C. AAS D. SAS
A SSA does not prove congruent triangles. In most cases there are 2 possible triangles that can be made
Mar 30, 2017 | The Computers & Internet
Why is overdrive light flashing orange when the car warms up and has been driven for about 8 miles?
/D OFF Indicator The instrument cluster receives the O/D OFF indicator status from the PCM over the communication network. When the overdrive function is turned off, the PCM sends a command to the instrument cluster to turn on the O/D OFF indicator. When a powertrain concern exists, the O/D OFF indicator flashes amber and illuminates green when overdrive is selected off. What code ? you said solenoid A -
P0750 SSA SSA Solenoid Circuit Failure SSA circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. No reverse gear (short) or no 4th gear (open). MIL on. Go To Pinpoint Test A . P0751 SSA SSA Functional Failure (Stuck Off) Mechanical or hydraulic failure of the shift solenoid. Not all gears present, MIL on. Refer to Diagnosis By Symptom . P0752 SSA SSA Functional Failure (Stuck On) Mechanical or hydraulic failure of the shift solenoid. Not all gears present, MIL on. Refer to Diagnosis By Symptom . P0753 SSA SSA Solenoid Circuit Failure SSA circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. No reverse gear (short) or no 4th gear (open). MIL off. Go To Pinpoint Test A . Could be a wiring problem . Did you check the solenoid A wiring circuit back to the PCM ?
Dec 30, 2015 | 2007 Ford Focus 2.0
Code showing p1717 an po765 on my 05 mustang what dose that mean and how to fix it
Transmission Outputs
Shift Solenoids
The Shift Solenoid (SSA, SSB, SSC, and SSD) output circuits are checked for opens and shorts by the PCM by monitoring the status of a feedback circuit from the output driver (P0750 SSA, P0755 SSB, P0760 SSC, and P0765 SSD).
All vehicle applications will utilize an inductive signature circuit to monitor the shift solenoids functionally. The ISIG circuit monitors the current signature of the shift solenoid as the solenoid is commanded on. A solenoid that functions properly will show a characteristic decrease in current as the solenoid starts to move. If the solenoid is malfunctioning, the current will not change (P1714 SSA, P1715 SSB, P1716 SSC, P1717 SSD). The ISIG test runs in conjunction with the other transmission functional tests. The lack of communication between the ISIG chip
and the PCM microprocessor is also monitored (P1636).
https://www.motorcraftservice.com/vdirs/diagnostics/pdf/OBDSM508.pdf
May 26, 2015 | 2005 Ford Mustang
Owners manual for ssa -s1d 7800 starsound amp
Try to locate their website, and look for it there.
Jun 05, 2014 | Audio Players & Recorders
Hi Guys I have an Starsound SSA-4495 series amp,
seems that the amp is fried, have it repaired.
Sep 16, 2013 | Car Audio & Video
What does error code t/r Toshiba capasee ii mean plz help me
the T/R error showing capasee 2 reason
1st. Transducer
OR
2nd. pulsor board
1st Solution you change a Transducer and remove the error
if not remove it 100 pulsor board error
i repairing a pulsor board at component level many of times.
Aug 11, 2013 | Toshiba Capasee:ssa-220a Ultrasound W/1...
Hi I've plugged it in and all indications, green light on, heated water.. it wont steam,
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ssa
Jan 01, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
70 people viewed this question
 Grubhead
Grubhead
