Question about Asrock 775VM800 Motherboard
'mac address are invalid in both cmos and flash'
"mac address are invalid in both cmos and flash"
I'm getting this error on my ASROCK P4VM890 at bootup after flashing my mobo's bios "mac address are invalid in both cmos and flash" "Press F1 to continue"
experienced this error and have a solution?
I also found this http://www.asrock.com/support/Download/MAC_tool_dl.htm but I'm not sure whether it works with my mobo. Anyone know?
__________________JOHN..
  • Anonymous Oct 31, 2008
    i have same problem ,,,i have a motherbord asrock p4vm890 "mac address are invalid in both cmos and flash" help me PLEASE !!!
K, i hv a solution for u, first u need to download afudos utility from http://www.ami.com/support/downloadagreement.cfm?DLFile=support/downloads/amiflash.zip&InpDrvID=90. And then go to DOS mode, n type command like,
D:\...........\afudos /mxxxxxxxxxxxx
There is /m is the command n 12 times x is ur mac ID. N u can find ur MAC on some were on ur MB.
I think this will fix ur problem.
Posted on May 16, 2008
Error mac address are invalid in both cmos and flash
does your mac have a battery back up battery like pc's do.
the battery in the mac may not have enough power to keep the cmos information together, replace the battery and you should be okay
Sep 23, 2014 | Asrock Computers & Internet
Mac adress are invalid in both CMOS and Flash
i have your problem.but when i use asrock mac tool it said "Not supported"!.infact it not supported mac address on stick on main board!but my hope was the mac 6 digit that newer tool write.then i change my mac by mac changer from windows and then set that mac to bois and flash by asrock mac tool.every thing get ok:)
Jun 19, 2014 | Asrock Computers & Internet
Asrock 775dual-vista mac address are invalid in both cmos and flash'
reinstalling your os has nothing to do with bios, you are getting this message long before any hard disks are involved in fact the bios doesnt even have the interrupts running for the USB devices at this point, you'll notice this if you have a USB keyboard. The only possible solution is to flash or replace your BIOS chip - this is a LAST RESORT option. I dont recommend it if the system works other than the LAN. Your best solution is to install a network card in a free PCI slot, they are pretty cheap if you know where to look, heck even goodwill carries them in their 1$ computer junk bin thats where i bought a few of my 100baset cards (of course at your own risk) hope it helps
Feb 06, 2012 | Asrock 775VM800 Motherboard
My asrock p4vm890 is has invalid mac address for both cmos and bios
The MAC is the unique identifier for the onboard LAN chip - if it's invalid then the chip has been fried - disable it from the BIOS and install a new PCI LAN card.
Mar 27, 2011 | Asrock P4VM890 Motherboard
Modelo: ALiveNF6P-VSTA Problema: MAC address are invalid in both CMOS and Flash!
The onboard LAN chip has been fried. Disable it from the BIOS and install a separate PCI LAN card.
Feb 13, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
"MAC address are invalid in
Find the highest version bios flash file 1.50 and do it from DOS from a Boot Floppy or CD
http://www.asrock.com/mb/download.asp?Model=775VM800&o=BIOS
Feb 05, 2011 | Asrock 775VM800 Motherboard
My machine has this problem. every time i switch it on it says mac address are invalid in both cmos and flash. what do i do?
configured the BIOS settings yet? Make sure your set the RAM to run as Supports DDR400/333/266 non-ECC, un-buffered memory Max. capacity of system memory: 2GB
the RAM you installed and to match the CPU bus. And there's probably several other settings that need to be tweaked as well. For example, if you're not running RAID, disable it.
If the problems continue, you may wanna try updating the BIOS. Actually, I just had a look at the ASRock site & here's what the latest BIOS fixes: "Modify MAC address function algorithm"
http://www.asrock.com/mb/download.asp?Model=K7NF2-RAID&s=462
Nov 07, 2010 | Asrock 775VM800 Motherboard
Mac address is invalid in both cmos and flash
The MAC address is burned in the Ethernet card chip, you won't see it in the Bios or if you do you can't change it. MAC address changer are tweaks to not being tracked.
The solution to know if the card is blown is to do a complete reinstall of your operating system and if then you can't connect whit it, it is indeed dead. Then Disable it in the Bios and had a PCI one to replace it.
Those kind of problem whit network cards happens a lot when you get a power outage, if you had one in the last couple of days your problem is most likely it.
May 27, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Mac address wrong in both cmos and flash press f1 to continue
MAC address is not held in CMOS. Please describe the symptoms - what hapens when you switch on, what does message say exactly?
Nov 22, 2008 | Computers & Internet
Samsung vm8000 laptop
run cmos setup and try to configured in factory default settings...
Mar 23, 2008 | Computers & Internet
Asrock 775VM800 Motherboard Logo
6,821 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
