Question about Samsung CLP620ND Colour Laser Duplex Printer
My printer asked me for changing the Roller pickup , after i changed it the printer is still giving me the same error on the screen so i think i need to do a counter reset somehow , so if you can help me with that please?
Where I can get a list of spare parts? I need a axle with a pickup roller and I didnt find it anyway,tanks!
I don't have the parts list but what you want is: Pickup roller QM3-4668-000 and Pickup roller holder assy QC2-9055-000. The roller was changed and these two parts go together. I suppose you could take the rubber tyre off the new one and fit it to your old one if the diameters are the same.
May 17, 2016 | Canon PIXMA iP1800 InkJet Photo Printer
ERROR 024-959
Xerox 6605 paper tray empty error, the paper detect sensor arm and pick up roller get out of place. remove paper detect sensor arm and pull down on pickup roller assembly it should be springy not stiff. once it springs again, put paper detect sensor lever back on, on the right side of that lever gets tucked behind pickup roller assembly. hope this helps. The Magic Man!
May 29, 2014 | Xerox WorkCentre 6605/N Color Laser...
Error 13.01.00 - Jam in Tray 2. There is no jam. We've changed the pickup roller and separation pad twice. Problem started after technician installed the first pickup roller/separation pad set for routine...
try it without the separation pad. Since the problem started after the maintenance, it may nt be in properly. As you are getting the rubber on the paper, the roller is turning, but the paper is not going anywhere giving the error
Oct 23, 2013 | HP LaserJet M3027 MFP Printer
Tis can't pickup the paper and its making noise
If your printer can not pick up the paper then you need to change the pickup roller and separation pad. You need to get the preventative maintenance kit RK-1320, this has the roller, pad and transfer roller. It is available:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
Oct 16, 2012 | HP LaserJet 1320 Printer
The printer is unable to grab the top sheet from the paper tray and gives me an error that no paper is fed. I have to open the paper tray and push the paper back down and hit the start button. This is...
its a paper pickup problem. remove the tray and look for rubber roller in the front.. try to wipe it with wet cloth. if it works, then you have to order and change (or get changed in service center) paper pickup assy.
Sep 19, 2011 | Brother DCP-7020 All-In-One Laser Printer
The printer thinks there is a paper jam-when we ask it to print it doesn't "grab" the next piece of paper-it clicks and then give a "paper jam" message please help
Typically these failure-to-feed problems are due to worn rollers - the feed roller is so worn
that it fails to feed the sheet of paper, which the printer misinterprets as a paper jam (because a
sensor tells the print processor that the sheet of paper is not present where is should be, and
therefore the printer microprocessor software issues a "PAPER JAM" error message).
The printer repair tech solution to this problem is to install a "roller kit," which entails the
replacement of every roller in the printer (since they all wear at about the same rate, replacing
just one is less effective than replacing them all).
Your quickie (temporary) solution - get the roller damp (this makes it grip a little better), then
load the paper tray to its maximum (pushing the paper into the paper pickup roller), then print a
couple precious pages while you order the roller kit online, and text your handy geek friend
who can change out all the rollers in your printer for a pizza.
Feb 18, 2011 | Canon PIXMA iP1600 Printer
HP Laserjet 2430n printer won't see the paper in Tray 2. Continues to give in display paper size *letter and *plain but I set it and it just comes back asking again. When you print it won't pickup from...
Yes I checked the tray throughly. I also changed to paper to legal plain and changed the configuration...still came back on the display panel change paper size...just won't stop asking.
If I put the add-on paper tray 500 sheet that tray works fine.
I was thinking though I might order another paper tray and try it since I replaced the pickup assy and still have problems...what do you think
I also cold reset the printer just in the event something was set wrong...still has problems
Oct 15, 2010 | HP LaserJet 2430tn Printer
Front & Back copies, paper has jammed cadrej side some time only.
You need to replace not only the pickup roller but all three paper roller: Pickup, Feed, Separation.
Aug 08, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Printer will not pick up paper and gives a paper jam error at tray 1. There is no paper jam.
change or clean the pickup roller for the first tray, and make sure no small paper stucking on sensor , check the sensor if its on right place or not broken. and u will be fine.
Clean the pickup rollers by alchohol
Mar 09, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
Samsung CLP620ND Colour Laser Duplex Printer Logo
374 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
