Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not detecting - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
  • 61 Answers
There could be a lot of reasons why this could happen. Don't worry, i found two links, that might be of help to you.
If you are using Windows XP, go to this link
: - http://www.kingston.com/support/usbflashdrives/faq/pcdt_19.asp
If you are using Windows Vista, go to this link
: - http://www.kingston.com/support/usbflashdrives/faq/pcdt_20.asp
Hope this helps you.
Cheers!! Have a nice day.
Posted on Sep 15, 2010
How to solve NG at split line prior detection konica minolta c451
Functions
• To set the detection level for the pre-detection of stain on the ADF original glass.
Use
• Use when changing the setting for whether or not to detect the stain on the ADF original glass when opening/closing ADF as well as its detection level as the main/sub power being ON, recovering from the sleep/low power mode, etc.
Not Set : Detection of stain on the glass will not be conducted.
Low : Stain on the glass will not be detected easily.
Normal : Normal level detection.
High : Stain on the glass will easily be detected.
NOTE
• Be aware that selecting "Not Set" and performing the pre-detection with the following setting will display "NG."
[Service Mode] ? [Machine] ? [Thin Line Prior Detection]
• When "Not Set" is selected, the original glass cleaning operation after the job ends does not operate.
Setting/Procedure
• The default setting is "Normal."
Not Set Low "Normal" High
Sep 12, 2016 | Konica Minolta Office Equipment & Supplies
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
Check engine light code p2196,p2197, po300 ,304,305,306,p2 ,Im freeking out.
P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0305 Cylinder 5 Misfire Detected P0306 Cylinder 6 Misfire Detected P0307 Cylinder 7 Misfire Detected P0308 Cylinder 8 Misfire Detected P0309 Cylinder 9 Misfire Detected P0310 Cylinder 10 Misfire Detected P0311 Cylinder 11 Misfire Detected P0312 Cylinder 12 Misfire Detected P0313 Misfire Detected with Low Fuel P0314 Single Cylinder Misfire (Cylinder not Specified) P0315 Crankshaft Position System Variation Not Learned P0316 Misfire Detected On Startup (First 1000 Revolutions)
Read more at: http://www.obd-codes.com/trouble_codes/
Copyright © OBD-Codes.com
P2195 O2 Sensor Signal Stuck Lean Bank1 Sensor 1 P2196 O2 Sensor Signal Stuck Rich Bank1 Sensor 1 P2197 O2 Sensor Signal Stuck Lean Bank2 Sensor 1 P2198 O2 Sensor Signal Stuck Rich Bank2 Sensor 1
Copyright © OBD-Codes.com http://www.obd-codes.com/p0002
May 07, 2015 | 2006 Ford Taurus SEL
Missing,viborating
Misfire could be a number of things:
a) spark plugs - change them if used over 15K miles - inspect/regap.
b) spark plug wires - change them if over 15K miles - inspect
c) ECM (electronic control module) - test with HEI (high energy ignition) tester.
The vibrating tells me that the engine is running on less than its normal compliment of cylinders - the shaking is produced by the imbalance caused in the engine by one (or more) cylinder(s)
not firing at all.
The "Check Engine" light probably is coming on due the the misfire condition. Go to Pep Boys or
Advance Auto Pats, where they'll tell you (free) your codes causing the "Check Engine' light to be
lit - the code coming from your truck's computer will probably be one or more of:
P0300 - Random/Multiple Cylinder misfire detected
P0301 - Cylinder 1 misfire detected
P0302 - Cylinder 2 misfire detected
P0303 - Cylinder 3 misfire detected
P0304 - Cylinder 4 misfire detected
P0305 - Cylinder 5 misfire detected
P0306 - Cylinder 6 misfire detected
P0307 - Cylinder 7 misfire detected
P0308 - Cylinder 8 misfire detected
P0313 - Misfire detected with low fuel
Jun 23, 2011 | 2009 Ford F-150
Is there a list for computer codes for 1980-1990's Chrysler Le Baron
Yes here is that list.
Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
Part 1: Chrysler Domestic vehicles
CODES/Meaning
88 display used for start or test
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle positioner sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 wastegate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects overboost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eeprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
May 31, 2011 | Chrysler LeBaron Cars & Trucks
I have a 05 VW Pessat with a 1.8L 65K miles on it. I have a random misfire and surge at idle. Code's set: P0300, P0301, P0302 and I seen P0303. This misfire comes and goes. Does not have a dead miss. I...
Try the crank pisition sensor that is vary likely to be the couse of your misfires its working but its intermintly shorting out telling the pcm that you have a misfire and setting the codes
Nov 22, 2010 | 2004 Volkswagen Passat
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
Model sf-2022 not running shows f1 on key pad
If you hold down the copy button, the machine will flash a set of two more digits at you. Check out what the digits are then compare your problem with this chart =].\
00 Sorter communication trouble detected
01 Paper jog malfunction detected
02 Transport motor malfunction detected
04 Indexer lower limit detected
05 Indexer upper limit detected
06 Shift motor malfunction detected
Aug 09, 2009 | Sharp Office Equipment & Supplies
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
43 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
