Question about Makita Garden
Makita dcs34 2 stroke petrol chainsaw problem is the unit will stop when tipped on either side and unit floods ( 2 stroke fuel mix comes out muffler ) unit has had new carb kit and tank breather appears to be working fine lets air in under a vacuum and will hold pressure manifold boot to cylinder is good and pressure and vaccum both held fine spark is good loaded and un loaded - compression excellent , muffler is clear , fuel hoses etc all good , tiimming key fine could it still be the fuel tank breather( ie tank pressurization ) and overcomming fuel needle valve spring pressure and flooding ? or a faulty fuel filter or a primer bulb or am i barking up the wrong tree or do these saws need some air space in the tank in oder for the breather to work , client may be overfilling ? can some one help or give me their thoughts cheers pauly46
steve_lima
  • 181 Answers
SOURCE: 455 Husqvarna chainsaw will not run
pull the muffler off and look for scoring on the piston,the 455 had a problem with running lean from factory and burned up a lot of pistons and cylinders
Posted on Jan 09, 2009
  • 2692 Answers
SOURCE: CHAINSAW WON'T START. BELIEVE IT'S FLOODING OUT.
Take the carburator off and clean it out.
Posted on Jan 18, 2009
  • 3567 Answers
SOURCE: honda pal 2 stroke scooter
Are you adding oil to the gas? (32/1 = 4 ounces per gallon)
Do you still have spark? Install a new stock spark plug.
Clean the carb, but follow these steps >
Remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Let the bike warm up then set the idle speed. This process should get you back on the road.
Posted on Mar 31, 2009
  • 30 Answers
SOURCE: I need an instruction manual for makita chain saw
you can purchase one from store.payloadz.com most manuals cost $ 8.99. hope this helps
Posted on May 26, 2009
bytestream
  • 70 Answers
SOURCE: Kawasaki GT750 Fuel dumping
Sounds like the float valve is stuck in the carby and allowing fuel to keep flowing.
Give the carby bowl a light tap with some wood to free up the float valve. You may have to pull the carby off and have a look if that doesn't help. Fuel cannot bypass the float valve in normal operation.
Posted on Jul 25, 2009
How do i mix my 2 stroke for a makita chainsaw how many ml of oil to a litre of fuel
Mix the fuel and oil in a suitable container that is airtight with a secure stopper to ensure the fuel mixture has a long shelf life. Keep the funnel, spout, container, etc., dry and very clean. Storing it all in a large plastic bag serves very well for this purpose.
Any quality engine oil can be used but an oil of the recommended type and viscosity will produce much better results. Purists and traditionalists still like to use vegetable oil but this has a very short useful life and dubious results. Self mixing 2-stroke oils are best and synthetic-based oils are reckoned these days to be superior.
Put fuel in the container first and then add the correct quantity of oil for the number of litres of fuel, close the container and shake with vigour for a few seconds and then transfer the fuel to the tool.
The number of ml of oil to use per litre of fuel will vary depending on the engine type, manufacture and age. The fuel/oil ratio is often marked on the fuel tank or cap, 30:1, 40:1, 50:1, etc.. 50:1 would require 20ml of oil per litre.
Some 2-stroke oil bottles have a useful measuring scale on the side...
Aug 06, 2016 | Makita Garden
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
The person I bought it off said it takes 50 to 1 don't know how to measure that
50 to 1 means that for every 1 unit of (2 Stroke) oil you use 50 of the same units of petrol. Most 2 stroke oil bottles have a measure on the side which you use to measure how much oil you're using so for 5 Litres of petrol (approx 1 gallon) you would use 100ml of oil.
50 to 1 which is usually written as 50:1 is a very light mix. Husqvarna saws use 40:1. You need to use good quality 2 stroke oil from tool hire shops rather than the cheaper stuff you can buy at petrol service stations. Some makes of 2 stroke oil, like Stihl, have a measuring cup on them with ratios marked on the side. To fill them you take the cap off the measuring cup and fill to the mark at 50:1 by squeezing the oil bottle. Then pour that into 5 litres of petrol. You can also buy mixing bottles in some hardware stores with ratios marked on them. You fill the oil up to the mark 50:1 and then fill it up with petrol to get the right mix.
Dec 23, 2010 | Garden
What is proper gas mixture?
fuel mix ratio is 50:1 using good quality 2 stroke oil
ie if you mix 20 mils of oil for every 1 litre of petrol that you mix
that is 50:1
or if you want a 5 litre mix put in 100 mils of oil into a clean petrol container 1st then put in 5 litres of fuel only and give good shake
cheers paul
Aug 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
91 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
