Question about Cameras
Cannot take pictures screen says memory card locked. I can view pictures taken only
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 15, 2010
Won't take/record photos!
Are you sure it is set to save images to the card and not the camera's internal memory ?
Mar 28, 2017 | Konica Minolta DiMAGE F200 Digital Camera
I can view pictures already taken but the camera says card locked how can I solve this please
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 15, 2011 | Acer CE-5330 Digital Camera
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
Can not view pictures
No this camera does not have any internal memory. All images should be written to the memory card if the memory card is inserted properly. If the memory card is not inserted correctly the camera screen will show a message of No card. Do you see that message?
Apr 27, 2009 | Olympus E-520 Digital Camera
Distorted/damaged pictures
Please check the image size (pixels x pixels) setting or the resolution (MP). Seems like the camera is shooting in low resolution. Have you used this memory card on a mobile phone or another camera? Format the memory card and try again.
Feb 14, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Nokia n82
just flash ur mobile by using code--- *#7370#
then type lock code and wait ....but by this u lost ur contact number and msg...so plz take backup by using nokia pc suite then do this ....then format memory card and used ...it working in most of the handset,.
Sep 15, 2008 | Nokia N82 Handheld
Unidentified Image
Usually the only time this message will appear is when you have taken the picture with another camera and try to review it on another. If this is not the issue, try formatting your card. Try another card. It may be a faulty memory card. If none of this works, call Canon tech support for free support.
May 28, 2008 | Canon PowerShot S51S Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
View screen sticks on view mode when switch to take picture mode
This is a button/firmware problem Canon Customer support will advise on your next move -depending on the age of the camera
Jun 28, 2007 | Canon PowerShot A75 Digital Camera
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Cameras Logo
52 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
