Question about Sharp R-510HW Microwave Oven
The oven is arking and smoking by the light but not everytime it is used
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 15, 2010
My whirlpool microwave built in oven emitted smoke
Hi Dagmar
So... you've indicated that your microwave oven has an obvious serious problem.
You didn't have any questions?
The Answer would be pretty obvious anyway!
Cheers
Better Luck with the New One!
FURTHER:
The main component in a Microwave oven is the Magnetron. This generates the microwave energy which is released into a resonant tuned cavity (antenna) that heats the food. Testing the Magnetron would require specialised tools & knowledge. Beside the fact that it would be very dangerous. The Magnetron is often driven by electronics like a switch mode power supply & an inverter. It is possible that the switch mode or inverter has failed and burned out. There can be Electrolytic Capacitors that have failed (leaking or popped) causing the electronics to fail. If you have some expertise in this area then you could open up the unit and inspect for what has failed. Unplug power and never operate the unit while inside. Pull out suspect electronics module's, repair and seal unit up before turning on. The mere fact that you had heated internals is a warning of major problems.
Really, you are better off & safer taking the unit in to a Microwave Repair Technician.
Jul 07, 2015 | Whirlpool Microwave Ovens
I have sparkin and arching in the magetron cavity
remove cover inside microwave oven and clean the cover and the metal around it if it still arks replace the megnatron
Dec 06, 2013 | Maytag UMC5200BA Microwave Oven
On rt side a plate about 4"x5"looks like alunium foil about 1/32" thick arks+sparks inside?
heatman101
Apr 17, 2011 | Magic Chef MCD1311ST Microwave Oven
I placed food in the microwave over to heat for 19 seconds, when it was finished I smelled smoke coming from the oven. The food was fine. I unpluged the oven. I tried it a couple of days later, it...
the smoke probably came from the heated food. try using it next time with different kind of foods and also try it to the same kind of food that produces smoke but observe carefully what will happen.
Dec 29, 2010 | Emerson Microwave Ovens
Microwave is arking is there a solution?
Hi!!
Unplug unit from wall outlet and remove the two screws on each of the bottom sides to remove the metal cover, check wiring insulation and for a loose or disconnected wire. Check on the inside of the cover for burnt marks, that will give you an idea of where the problem may be. Use needle nose pliers to handle and plug wire terminal back up.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 02, 2010 | LG LRM1260SW Microwave Oven
Hi. I have a Maytag mmv5207bcs Microwave. Pressed...
mmv5207ba/bc microwave 0 button fan on button does not work all other key pad buttons seem to work
May 21, 2010 | Microwave Ovens
Sharp convection microwave arking
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Mar 12, 2010 | Sharp R-1850A Convection/Microwave Oven
Why is my microwave oven sparking?
if the paint on the inside of the micro is chipped off in some places, it will ark to the exsposed metel
Nov 17, 2009 | GE JVM1870 Microwave Oven
Sharp R-510HW Microwave Oven Logo
115 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
