Question about HP Pavilion DV6449US Notebook
The DVD writer to my HP Pavilion dv6449us laptop will not run a program installation disk and does not show up as a device in "My Computer". Occasionally I can start with a system boot disk created with DriveScrubber3 and with a Norton Ghost 12 & 15 System Recovery Disk. Also, the computer will not recognize an external DVD writer. The external drive did work for a long time after the internal DVD writer quit but then also went kaput. The computer does recognize an external hard drive. I had a chip replace last winter to fix the failure of the computer to boot up at all Ted Mills
  • HP Master
  • 11,800 Answers
Click on the Start menu.
In the search box type in "regedit" without the quotation marks.
Go to the following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right panel you'll see something along the lines of "UpperFilter" and "LowerFilter" you want to click on each "filter" key and hit delete. Click yes when it asks to confirm if you wish to delete the key.
Restart Windows.
If this doesn't fix it then it's a hardware problem - most likely the chip that was replaced has failed again.
In my personal opinion if this has happened before then the unit has a manufacturing defect - just junk it, not worth your time and money.
Posted on Sep 15, 2010
My hp dv6449us laptop powers up and shuts down immediately how to fix please
This could be a variety of different problems. Could be your battery failing or even something overheating in your computer. Have you ever had someone open and clean out your laptop?
Feb 16, 2013 | HP Pavilion DV6449US Notebook
Do I need sata or eide for internal dvd writer on HP a1330n?
This model HP has a SATA disk controller.
You need a SATA DVD writer.
If you are not sure, when you remove the faulty DVD writer, take it with you when you go to purchase a nre DVD writer, make sure the new DVD writer has the same connectors as the faulty DVD writer.
Jan 22, 2012 | HP Pavilion Media Center a1330n - AMD...
Hp dv6449us notebook pc
check the wireless driver in control panel , system, device adminitrator
Aug 01, 2010 | HP Pavilion DV6449US Notebook
Web cam and cd player/writer both stopped working for no reason and don't show up in device manager
whilel the laptop is on take the drive out of the laptop and reinstall it the computer should pickup that there is new hardware ad will install the drivres for it. after this is done the dvd drive should start to work again as for the web cam go to the hp web site and download the driver for it.
Jul 03, 2010 | HP Pavilion dv6000z Notebook
I am trying to make my startup disks but each timetime I try with recovery manager it says I dont have a cd/dvd writer yet my writer shows up in the device manager can anyone help.
Are you sure its a Dvd writer and not a Dvd-Rom with cd write capability? Cd write wont cut it for restore disks as restore disks can take several gigabytes of space especially if created by the Manufacturers program which would install crapware, trialware and other things not necessarily needed. You could create your own if that program does not work for you. If your hell bent on using it then navigate to the compaq support web site and open a case and a rep will help you with your issues. Good Luck!
Mar 09, 2010 | Compaq Presario Notebook
I have a Pavillion dv6449us running Vista. Have no sound from speakers except the Quickplay row beeps . Drivers are up to date and device working properly in device manager. Help please.
The operating system requires restoration once more in which instance adjsuting the device outputs capabilities to enbled before performing final restore to windows. this would allow the sounds to display directly by authorisation from operating system. The drivers may be installed like the situation and very part required to function but because the feature selection before the computer was restored has certian options set as disable makes least output.
Mar 04, 2010 | HP Pavilion DV6449US Notebook
HP Pavilion dv6516tx internal dvd writer not writing to blank dvd
you can check the capability of your drive with nero so you know which disk u can write to.
Jun 30, 2009 | HP Pavilion dv6000z Notebook
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
I found code error 88780078
check sound drivers in device manager
run-->devmgmt.msc
Jan 10, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion DV6449US Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
