Question about Toshiba Satellite A205-S4617 Notebook
If you take your Toshiba apart & evidently was not careful when removing the keyboard since it came a part from the motherboard. How do you reconnect? http://sunvalleyus.com/ToshibaKeyboard/
2 Suggested Answers
  • 514 Answers
SOURCE: i need to clean my laptop fan & my laptop model is toshiba satellite a300
Googled your question/ product and found the following guidelines at
"http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/laptop-disassembly-process-1.htm" There 3 pages with good pictures that you can click on to expand and it seems to have very detailed instructions there.
good luck!
Posted on Mar 02, 2012
Water on keyboard, now laptop won't start and makes noise
I would say the laptop is done. You have given it more than enough time to dry out so you have shorted out something on the motherboard. Remove the hard drive so that you have access to the information stored on it. You can pick up a refurbished laptop from micro center for under 200.00.
Oct 11, 2017 | Toshiba Satellite Computers & Internet
How to fix unworking TAB KEY
Try to spray "a little" wd-40 around the area, & wipe off all excess.
Feb 08, 2013 | Toshiba Satellite A135-S2276 Notebook
Toshiba p300 manuel
How to take apart a Toshiba Satellite P305 and Satellite P300 series notebook.
In this case I'm working on a Toshiba Satellite P305 notebook. Also, you can use same set of instructions for taking apart a Toshiba Satellite P300 notebook.
STEP 1
Turn off the laptop, unplug the power adapter and remove the battery.
In the battery compartment remove three screws securing the keyboard bezel.
STEP 2
Remove the keyboard bezel with a small flathead screwdriver.
STEP 3
Remove two screws from the keyboard.
STEP 4
Lift up the keyboard as it shown on the picture and place it upside down on the palm rest
STEP 5
Unlock the connector on the motherboard and release the keyboard cable.
Remove the keyboard. \
STEP 6
Remove one screw securing the CD/DVD drive.
STEP 7
Push the CD/DVD drive from the laptop and remove it.
Electrostatic Discharge (ESD) can kill your computer
ESD can permanently damage your laptop. Always ware ESD wrist strap when you work with internal computer components.
How notebook screws are marked
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized.
Removing Memory Modules
Carefully spread latches on both sides of the memory slot with your fingers.
Carefully pull the memory module from the slot by the edges.
Removing Wireless Card
There are two antenna wires connected to the wireless card.
White wire connects to the main connector on the card.
Black wire connects to the auxiliary connector on the card.
To disconnect the antenna wire from the wireless card grasp the connector with your fingers and unsnap it from the card.
Carefully spread latches on both sides of the wireless card slot, just enough to release the card.
The wireless card will pop up at 30 degrees angle.
Pull the wireless card from the slot by the edges.
Disconnecting Keyboard
Before you pull the keyboard cable from the connector on the motherboard, you'll have to open up the connector.
After the connector is unlocked you can pull the cable. Be very careful with the connector. If you accidentally damage the connector, you'll have to replace the motherboard.
Removing Modem Card
The connector is located under the modem and you cannot see it until the modem is remove. After the modem is removed, disconnect the cable (on the left side).
\Usually the modem is secured to the motherboard by two screws. Remove them.
To disconnect the modem from the motherboard lift it up.
CPU came out attached to heatsink
In some cases, when you remove the heat sink, the CPU might get out attached to the heat sink. DO NOT install it back into the socket like that, separate the CPU from the heat sink first.
CPU came out attached to the heat sink because thermal paste dried out and glued the processor.
Insert a flathead screwdriver between the CPU and the heat sink surface. Carefully rotate the screwdriver until the CPU separates from the heat sink.
\Lift up the CPU and install it back into the socket on the motherboard. Now you can safely remove old thermal paste and apply a new layer of paste.
Removing and Installing CPU
The CPU is locked in the socket. Before you can remove the CPU, you'll have to unlock the socket. Use a flathead screwdriver and turn the socket screw to "Open" position.
Lift up the CPU by the edges. Be careful, there are a lot of fragile pins on the opposite side of the CPU. You should be able to install the CPU back into the socket without any force.
There is only one correct way to install the processor into the socket. Both CPU and socket are keyed. When you are installing the CPU, make sure to match pins on the processor with holes on the socket.
Before applying thermal grease on the CPU, clean the surface with alcohol.
After the CPU surface is cleaned, apply a small drop of thermal grease.
Spread thermal grease evenly and install the heat sink.
ATTENTION! If you forget to lock the CPU in the socket, the laptop will not boot. If you install the heat sink without applying thermal grease, the CPU will overheat.
Dec 20, 2011 | Computers & Internet
My mousepad does not work on my Toshiba Satellite L305d after i took it apart
Remove the keyboard and check the keyboard and mouse pad connections on the motherboard. Make sure they are inserted securely on the motherboard.
Dec 20, 2011 | Toshiba Satellite L305D-S5874 Laptop
My keyboard has sticky keys. How do I disassemble the keyboard?
Hi
STEP 1
Remove laptop battery.
Remove two screws securing the hard drive cover. Remove the cover.
Remove one screw securing the memory cover. Remove the cover
STEP 2
Pull the hard drive to the left. Disconnect it from the motherboard and remove.
Remove both memory modules.
STEP 4
Remove all screws from the bottom of the laptop.
STEP 5
Remove the keyboard bezel using a smal flathead screwdriver.
Be careful, it's fragile.
STEP 6
Remove four screws securing the keyboard.
Press on the plastic lock (red arrow) and release the keyboard.
STEP 7
Lift up the keyboard.
Be careful, it's still attached to the motherboard.
Feb 22, 2011 | Toshiba Satellite L305-S5894 Notebook
How do i remove the keyboard on a toshiba M55-S3314 laptop?
You will need to use a pocket knife, or flat object to pry up and remove the plastic strip above the keyboard first. I'm pretty sure it is held in place by pressure only, no screws yet (see NOTE below). Once this piece is removed, it exposes two screws that hold the keyboard in place. Remove these screws, and you should be able to lift the keyboard from the laptop. Be careful, as the keyboard is still connected to the motherboard by a ribbon cable that needs to be disconnected. Once you release this cable from the motherboard, you should be clear to separate the keyboard from the Toshiba.
NOTE, if you are having trouble removing the plastic strip from above the keyboard, flip the laptop over and remove the battery. Look for any screws that may be holding it in place and remove those first.
Jul 21, 2010 | Toshiba Satellite M55-S3314 Laptop
How do I take apart my toshiba laptop
unscrew it from the bottom with a tiny screwdriver, there are also some spots that you cant really see unless you take off the plates. when its all unscrewed use a wedge and pop the top of the keyboard off... there will be 4-5 wires connected from the keyboard plate to the motherboard. unplug those and your set. its apart :) hope this helped ya
Nov 16, 2009 | Toshiba Satellite A135-S2386 Notebook...
Replace keyboard on Acer 4720Z
Hi..
I will provide you a solution this solution are very useful with you. You can do it with your self to follow this instructions. There are some image on how to replace the keyboard.
These instructions will help you to remove and replace keyboards on various laptops. I will not be able to cover all models but you’ll get the idea. Steps for removing and replacing the keyboard are similar for most laptops.
Warning!
- if your laptop is still covered by the manufacturer’s warranty, do not open the case or you can loose the warranty
- always remove the battery and unplug the AC adapter before you open the laptop case
- if you damage the keyboard connector on the motherboard you’ll have to replace the whole motherboard
- proceed on your own risk
Sony laptop
I took these pictures from a Sony Vaio PCG-K33 (model PCG-9S1L) notebook. Should be similar for some other Sony notebooks too.
sony-keyboard-1.jpg Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers.
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
sony-keyboard-3.jpg Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laptop case.
sony-keyboard-4.jpg The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you’ll have to unlock the connector.
sony-keyboard-5.jpg The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
Toshiba laptop
The following pictures were taken from a Toshiba Satellite A135 laptop. The keyboard removal instructions will be almost the same for most modern Toshiba laptops.
toshiba-keyboard-1.jpg The keyboard bezel removal procedure is similar to the above mentioned Sony Vaio laptop. Lift it up with a small screwdriver and remove using fingers. On most Toshiba laptops the keyboard bezel doesn’t have any circuit board underneath, it’s just a piece of plastic and you don’t have to worry about cables.
toshiba-keyboard-2.jpg After the bezel is removed you get an access to the keyboard screws. Remove two (or more) screws. Release the plastic latch pointed with the red arrow and lift up the keyboard. Carefully put the keyboard aside so you can access the connector underneath the keyboard. Do not forget that the keyboard is still connected to the motherboard.
toshiba-keyboard-3.jpg Before you remove the keyboard, you’ll have to open the connector and release the flat ribbon cable.
toshiba-keyboard-4.jpg Here’s a closeup picture of the keyboard connector on the motherboard. Be careful, this type of connector is fragile. On the left image the connector is closed. On the right image the connector is opened. Unlock the connector by moving the lock up as it shown on the right image and after that release the ribbon cable. Remove and replace the keyboard. For assembly instructions follow all the steps in the reverse order.
Hope it is helpful for you!
Thanks for using Fixya
Regards
ICmanServer
Aug 04, 2009 | Acer Computers & Internet
Replace keyboard Sony
Hi..
Warning!
Sony laptop
Toshiba laptop
Regards
ICmanServer
Aug 02, 2009 | Sony VAIO VGN-BX543B Notebook
How do I dissasembale Asus A6J laptop
Short of doing it for you, I would suggest to get a clean area to work on, a place to put all your screws that you will be removing... ideally a tray or drawer for every set of screws. Get yourself a good digital camera to record your process. This helps when you want to rebuild your system back. Above all, work slowly and paying close attention to every step that you take. I can't stress it enough to document your work, you can get lost very quickly doing this. I do this all the time, I have notes, but not for this particular laptop. I would start you off by removing the bezel that covers the power buttons, Normally I would work from right to left, gently prying up the bezel with a small screw driver. The exposed screws will remove the keyboard, be careful of the ribbon that attaches the k/b to the motherboard. You will work your way down to the system, but I would start cleaning the keyboard first. Good luck to you. Keep us updated. -Carlos:
Jun 15, 2009 | ASUS A6J Notebook
Toshiba Satellite A205-S4617 Notebook Logo
123 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
