How do a setup the router and modem on my laptop to receive my wireless internet
  • Adrian Buenaventura Sep 15, 2010
    what is the model of your wireless router?
  • 6,487 Answers
In order for us to provide you the step by step procedure that you need to configure the router to work with your modem and to make the wireless connection work we need some information like the brand and model of your modem and router and also your computer including the operating system.
Posted on Sep 15, 2010
I have a viewsonic netbook and want to go on line wireless what do i need apart from a reuter
Requirement to setup a wifi internet connection
1. Modem (Provided by ISP - Internet service provider) 2. Wifi enabled Router (It has to be setup with modem to access internet, ie Modem and router connections using an Ethernet cable) 3. Computer with Wifi LAN adapter ( For receiving wireless signals from Router)
Let me know if you need any assistance in setting up router for wifi access.
Please rate if you like my solution Thanks
Jun 23, 2011 | D-Link Computers & Internet
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Wireless connection not working
Have your ISP setup your modem/router on there end its not setup yet.
Apr 11, 2009 | HP Pavilion dv6105us Notebook
I tried to reset my security password and now it won't work.
Make sure you have the physical connection connected properly.
-Modem should be connected to the Internet/WAN port of the router.
-Your laptop must be connected to port 1 of the router as well.
-Make sure you can go online hardwired to the router.
Then configure the wireless settings of the router by accessing the router setup page http://192.168.2.1, change the wireless settings.
Jan 19, 2009 | NetGear WGR614 Wireless Router
Still No Internet
I understand. You're two computers needs to be both connected to the router. Can you tell me if your Desktop computer has an Ethernet port? Your modem should only be connected to your router. Then, the two computers have to be connected both to the router. The Desktop will be wired to the router using an Ethernet cable and the Laptop through wireless connection.
Then, access the router's setup page again. You know how to do it, right? Remember launching IE and typing 192.168.1.1? Once you're in Go to STATUS page and look for IP address. Please let me the IP address that the router receives from your modem.
The reason why you need to connect the computers to the router, is because your ISP gives only Internet IP address. If you will connect your Desktop through USB to the modem, then there is no Internet IP address left for the router for your wireless computer.
The router should be the one to receive the Internet IP address and it will be the one to share it to the two computers behind it.
Please update me about this.
Nov 18, 2008 | Linksys Wireless-G Broadband Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
