Question about Acer Aspire 4730-4947 Notebook
Hey hi this is nammy........my acer 4736z battery is not charging.....actually whn i plug in, the orange light comes for a while and it shows tht battery is charging but after a few seconds it loses connection ,and battery stops getting charged and if its not enough without battery too ,its not able to make connection.........so plz reply soon
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 15, 2010
  • zjuanko Nov 07, 2010
    you need to reset your battery..
    follow this steps.
    1. remove your battery while your laptop is off
    2. press the power button for 30 seconds
    3. connect the AC adapter (the power cord or the charger) to the laptop and plug it.
    4. press power button (after this your laptop should be ok)
    5. put back the battery and it will charge again..
I bought a new battery for my advent 4490 net book .the battery worked fine on the initial charged tht it already had but now whn the battery is now left with the 9% charge in it , i plug in my charger and...
I I have the same issue and i took my netbook to more than 4 electronic engineers, all of them said that doesnt seem there is a problem in my netbook though.
Mar 31, 2011 | Advent Netbook
When plugged into power supply and with battery, my battery light shows orange ( as if it were charging ) then quickly to green ( as if fully charged ). * When I push the power button, the...
Your battery is dying from heat. Most likely because you leave it plugged in for too long. I suggest buying a new OEM (not china knockoff) adapter, and replace the cells in the battery or just buy a new batter.
Mar 22, 2011 | Acer Aspire 4520-5582 Notebook
Hai there.... yesterday i bought new battery for my acer aspire 4520. Why the orange light keep blinking when the battery were charge???als0 there is no show the charge symbol on my screen??? I really...
when orange light is on it means it is charging and to know whether your system is charging just look at battery symbol where you will find a wire symbol on battery which show it is charging and when charge is complete orange light turns blue
Feb 15, 2011 | Acer Aspire One PC Notebook
I HAVE A 4736Z LAPTAOP .MY PROBLEM IS WHEN I CHARGE THE LAPTOP THAT TIME SHOWS CHARGING WHILE A SECOND THAT GONE CHARGING IS STOPED THAT TIME SHOWED POWER LIGHT AND LAPTOP CHE]ARGING LIGHT BLINKING...
Hi there charge the battery first then go in control panel and make the power setting. Make sure the low battery time make long & others too. After that if you face the same problem then its a time to change the battery & buy a new one. Thanks.
Dec 06, 2010 | Acer Aspire 4730-4947 Notebook
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
China nokia e71 camera problem
hi guyz plzz help me wid china e71 tht whn i m opening my camerait says tht camera module not ready
vishal
Aurangabad
Dec 24, 2009 | Cell Phones
O plz help me with motorola v3i charging
Run the phone till the battery dies, remove battery for at least 5 mins. Replace battery, charge overnight with phone turned off
Nov 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Orange battery light on, but computer says its running on electrc
Hi, the orange light is meant to show a charging status, so if you have orange light and its running on electric it just means its plugged in and charging.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Acer Aspire 4730-4947 Notebook Logo
252 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
