Hi, my desktop pc problem is the CMOS clock. i already put the new battery on it. when i shut down my PC and open it for the next day, the CMOS clock turn back to zero count. i already save it after i adjust it. but it goes to zero after i restart it. what happen with my pc? is it my motherboard or what.? thanks.
    Guru:
  • 382 Answers
Nothing happened to it. Try resetting the CMOS jumper
>turn computer off
>look for a 3-pin jumper that looks like this
hi,
>take that plastic thing that connects two pins and turn computer back on
>allow the computer to load windows
>shut the computer down properly
>put the plastic back TO THE EXACT PINS where to took it off from
>turn computer back ON and set regional settings, time, region, etc...
Posted on Sep 15, 2010
Diagnostic 1 ,4 and battery lights are stable
That's TWO Problems bro: Your RAM is not SEATED properly and the CMOS Battery is probably very low. Pop the Side panel open with the computer UNPLUGGED. Check to see how many slots of RAM are in the PC. REmove them one at a time, then put them back in carefully, listening for a type of CLICKING sound that indicates proper seating of RAM STICKS. Remove the CMOS battery and install a NEW One. It looks like a NICKEL. After that, plug up the computer with the side panel STILL off to check and see if the lights stop blinking. If they do, shut the computer down again, UNPLUG it and re-fit the side access panel. PROBLEM SOLVED!!!
Feb 19, 2013 | Dell OptiPlex GX520 PC Desktop
I have windows 7. When I shut down and then restart later or the next day the clock shows the time of shut down and then run ok but I have to reset it or click on internet sync and that works. Then the...
If this is an older PC (3-5 years or more) then most likely the backup battery on the motherboard has become weak.
On many motherboards this is a coin cell, which can easily be replaced (on others it is soldered in, though), just have a look.
Mar 24, 2010 | Computers & Internet
I have Aspire T300 and now I power off the PC then turn off at the powerpoint - On start-up the next day the time clock has stopped and check settings and calender is stopped - any clues?
Yes, your little onboard battery that keeps the CMOS backed up has probably gone flat.  The PC needs to be opened up to replace this little flat shaped battery.
Mar 10, 2010 | Acer Computers & Internet
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
My computer is locked
hi there,
try to shut off your pc and pull out the cmos battery on mother board for 5 to ten minutes,then put it back again and run your pc if the locked was disconnected.have a nice day.
Jul 24, 2009 | Acer Computers & Internet
CMOS problem
Change the CMOS battery(Motherboard Battery) and check....
Jun 05, 2009 | Intel D102GGC2 Motherboard
I ran into a emachine desktop 3 days ago, and reinstalled operating system, everything was working fine, however when i shut down and booted the next day, computer continued to reboot itself after passing...
there is usually a jumper with three pins beside the cmoss battery just move the jumper to the last two pins for 5 seconds and put it back that will reset your bios that may help
Apr 18, 2009 | Computers & Internet
Clock resets to Jan 1, 2008 everytime you shut the computer down
Your CMOS battery needs to be replaced. It's a round and flat silver battery found on the motherboard, it's 3V.
Jan 21, 2009 | E-Machines Computers & Internet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
