Question about Cuisinart DCC-1200 Coffee Maker
Reservoir Cover squeaks when opening and closing when hot. Bought unit at Costco.
  • klpete56 Sep 17, 2010
    The problem is that the plastic expands during the brewing process causing the plastic to rub against itself. Called Cuisinart. They told me to wait an hour or until plasic lid cools before opening lid.
  • 19 Answers
The squeaking could be from the steam during the brew cycle. My first suggestion would be to wait a couple of minutes after the brew cycle has finished (after you enjoy your first, delicious cup) then open the cover. If you notice any warping or if the problem persists call Cuisinart directly.
Posted on Sep 15, 2010
Top engine stays cool while bottom half gets hot. water reservoir high while radiator low.
First You have to bleed out all the air in the cooling system.
If that doesn't fix it then the system is probably clogged. Also the thermostat could be not opening.
Hope this helps.
Feb 21, 2015 | Cars & Trucks
Just bought wine cooler on line from Costco, December 1, 2014 and delivered December 4, 2014, uncrated and plugged in December 5, 2014.....unit motor runs hot as can be and top of cooler hot to touch.
Compressors run hot and are cooled by the cold gas returning to motor via suction line. If top of unit is hot it is because your condenser, (part that gets rid of heat collected from inside) is up there doing its thing. If it draws excessive current the built in clixon will shut down juice to motor. The smell is just the paint and after a while it will disappear.
Sep 09, 2017 | Furniture
Does the b60 have filter and were is it
The filter assembly is several inches tall, with a basket-like holder for the cartridge at its base. The unit snaps in place over the outlet in the base of the water reservoir.
Lift and remove the cover of the water reservoir, which is located on the left side of the coffee maker.
Turn the filter unit's round replacement date dial to two months in the future. This offers a reminder of when it's time to check and replace the filter.
Open the cage at the bottom of the filter assembly. Insert the soaked and rinsed filter cartridge, and then snap the cage closed.
Position the filter assembly directly over the water outlet in the base of the reservoir. Push the unit down slightly until the assembly locks into place. You should feel it click into position.
Oct 06, 2014 | Keurig B60 Coffee Maker
4 fans bought in April from Costco and pac tested. 1 makes a a funny sound when plugged and does not work.. Can this be brought to a centre to be repaired as a callout cost 55 pounds Many thanks Mrs...
It sounds like you bought these items online from Costco, unless you have a Costco close by. Using the term "pounds" tells me you are in England someplace. A repair shop should be able to repair the problem easily and quickly. The noise you hear might be from the motor that is trying to start. Did you try a different power supply to see if the problem is your power outlet? You might try that. Cheers.
Jul 16, 2011 | Honeywell Dryers
HOW DO YOU CLEAN THE RAZOR
Good day!!!
if you wish or need to clean you razor you only have to do is to open the cover (unscrew) then use a paint brush to clean the your razor after that put some oil to lubricate the razor and that's it..
thanks for using fixya..
have a nice day!!!
Jun 30, 2011 | Philips Philishave Cool Skin HQ5620
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Main wash door won't open on whirlpool model du810swkqo recently bought new home with new (?) dishwasher but it looks like the main wash door (where the soap goes) doesn't have room to open. any...
the cover is spring loaded. manually open the cover and pour some really hot water by the hinge, manually open and close few time, onec it is loose, put few drop of machine oil and work it again.
May 15, 2009 | Dishwashers
Don't understand how it works
This coffee maker has a hot water reservoir that heats and stores hot water so it can brew coffee faster. Once you fill the reservoir by pouring a potful of cold water into the top, you can turn on the switch at the side of the unit and in about 10 minutes the water in the reservoir will be hot. I usually leave this switch turned on to keep the water in the reservoir hot. The front switch turns on the pot warmer at the front of the unit, so it should be turned off unless you are making coffee or keeping a pot warm. To make a fresh pot, put a filter and ground coffee in the removable filter basket, slide the basket into the unit, place an empty carafe on the warming burner and using a separate container pour fresh water into the filler at the top of the unit. The fresh water displaces the hot water in the reservoir and voila, the coffee carafe starts to fill. The amount of fresh water you added is the amount of coffee you will end up with, less a little bit that might have evaporated if you only make coffee every morning or less often. Most units have a plunger under the filler lid that keeps the fresh water from going in to the hot water reservoir until you close the lid, so close it after pouring in the water. Also, turn off the front switch if the carafe is getting low or empty, as it can get hot enough to crack the carafe. If you're not going to be using the coffee maker for several days, turn off the side switch or unplug the unit to save energy and reduce evaporation from the reservoir. I love mine. It makes great coffee and is much quicker than the drip type.
Apr 14, 2009 | Bunn NHB Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
82 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
