My mother has a Mistral MSS3.3 that works great for cooling but wont heat. Do you know why ?
Need to know what error 6 on a minstrel air conditioner unit.Also can you scan and email me the manual for a Chunghop K 1028E 1000 1 Uinverisal remote. Thanks Gwenda
Hope this helps
error code is the fan in the head unit (indoor part) of the split system. After rining around for hours this morning - the number to get parts Mistral Bellini & Ringroup. 1300 373 199 They are based in Melbourne.
Apr 03, 2017 | Heating & Cooling
Mistral
need new fan ,,, or loose connection,, or new heater matrix which is expensive
Sep 06, 2014 | Heating & Cooling
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Nissan Mistral has a heating gearbox while running. What is the cause and how can I solve it?
is there a enough steering fluid on it check the belt of you power steering maybe it is not tighten also the power steering it self if it is working and check the belt tessioner.
Apr 30, 2009 | Nissan Titan Cars & Trucks
My heat won't work! Air blows out, new thermostat
The hot water from your engine cooling system is not getting into the heater core. Check out the valve that admits water into it.
Aug 23, 2017 | 1995 Audi A6
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
