Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Removing the top of the 7901-1 Bissell Proheat
Need to replace the pump on the 7901-1 ProHeat. How do I remove the top without breaking anything
    President:
  • 1,673 Answers
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
Posted on May 26, 2008
7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum: I have a Bissell 7901-1. I need to replace the pum...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
78iiry
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Replacing smart mix plunger bissell proheat model 7901 procedure for proper installation
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
I replaced pump and put back together now it wont release any soap// bissell proheat 7901
heatman101
mnm.
May 14, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat 1699-5 won't spray, belt ok
Hi There,
It sounds like to me that this may be your pump. The newer ProHeat 2X models actually have a Silinoid problem right now which is more common then the pump going bad, but if you have the original ProHeat series, then it sounds lik you have a bad pump.
Here's a link to a very, very helpful repair guide directly from Bissell that will explain to you step by step how to trouble shoot, and replace the pump if needed. I would be lost on the ProHeat series without this handy repair guide.
I'm pretty knowledgable now on these machines, if you need some help or some clarification on how to repair this, please feel free to reply to this repair by using the Clarification request form. If you found this helpful, please be so kind and rate my repair, and give feedback.
Here's the link:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-proheat-repair-guide.pdf
Thanks again,
Chris Jones
GoVacuum.com
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
heatman101
ghddgh
Mar 26, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat 7901-R not doing anything--ready to scream!
heatman101
ewtywe
Mar 12, 2009 | Bissell 7901-R Clearview Proheat Plus...
Proheat pump key
No; the new pump has a metal pulley which is more durable then red plastic pulley. be sure to place a 3/4 thick x 10 inch long (small shelf works) piece of wood under housing before removing top.
Jun 07, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to replace pump for 7901 bissell pro heat steam cleaner
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Jun 04, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
340 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
