Question about Cameras
Samsung es60 camara has a black spot while zooming. the black spot appears in the photo also
    Problem Solver:
  • 17 Answers
It could be there is something wrong with the lens or it needs to be cleaned. Check that and let me know.
Posted on Sep 15, 2010
Samsung es60 card locked solution
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 22, 2014 | Samsung ES60 Digital Camera
Samsung es60 flash problem
Try setting up your Samsung es60 on flash mode to turn on flash
Dec 25, 2013 | Samsung ES60 Digital Camera
Can you give me the softwere ES60
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Nov 12, 2012 | Samsung ES60 Digital Camera
It's a small black spot near the bottom left. It
it sounds like a small pieces of dirt got inside the photo mechanism and may need to be clean proffesionally
Jul 21, 2010 | Canon PowerShot SD1100 IS Digital Camera
Can I use any samsung usb cable for my ES60/ES63
Ebay has a usb/charger for a Samsung E63. Item No. 120530514745, for £13.99p. It also has a list of compatible cameras, therefore any of the mentioned cameras usb cable should be compatible with a E63.
Hope this helps.
Mar 12, 2010 | Samsung Cameras
Optio M20 Stuck on Zoom in and out!
you have a timing problem,the gears for your housing is out of calibration with your focus lens inside of the housing. you must take the camera apart to correct the problem.there is a flywheel type of ajustment in the top of the camera that can be turned to bring the camera back to its reset position. it is bad to keep turning on the camera as this may danage the gear that is out of time.
Sep 12, 2008 | Pentax Optio M20 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Black screen when camara is in photo mode
anyone else had this? or know what to do. whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
Jun 24, 2006 | Fuji FinePix S304 Digital Camera
Cameras Logo
164 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
