Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Just bought my 65" panasonic. The picture has too many dots. What can I do to eliminate this problem. It looks like a million tiny dots
  • 490 Answers
Whoa. You are so right. It is actually hundreds of thousands of tiny dots. You are not supposed to notice that, though unless you are sitting waaay too close to the screen or you have the worst cable connection ever. If you have checked all the connections and are sitting far enough away and it is still all dotty, then take that ****** right back and get a different one, no kidding.
I'm there with you,
Farmerbear at FixYa.com
Posted on Sep 15, 2010
  • Helper Nov 17, 2012
    stop being a smart *** in here.. if u dont know the answer... u should shut your big mouth
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
I have whit dots all over my tv how do you fix this problem
If the model number (Toshiba 65HM167) is correct the dots are a damaged Optical light engine.
These early units were DLP but had a 1/4 of a million micro mirrors in the optical unit--if they do not open and close correctly you get dots---seen some with 15 or more dots.
Mar 15, 2012 | Toshiba 65HM167 65" Projection Television
Little white dots in tv modle# wdt657 what are they how can i get them off
Your TV is DLP projection TV. DLP is Digital Light Processing. Digitally processed light coming out of DMD (Digital Micro mirror Device) is projected on the TV screen. This DMD is made of thousands of tiny mirrors & the size is about 0.7 inch. These mirrors are fixed with tiny hinges for its movement. They reflect light as per processed signal. DLP is invented by Texas Instruments. When there are dots on the screen, that means the tiny mirrors representing the dots are stuck in its position. If the dots are few & the viewing is bearable, just leave as it is. If the dots are more than bearable then you will have replace the DMD chip which is quite costly.
Sep 25, 2011 | Mitsubishi WD-Y657 65" HDTV
Looks like bunch of white dots, kinda like a plantatearium
SOUNDS LIKE A DEFECTIVE DMD CHIP STANDS FOR DIGITAL MODULE DEVICE. I DONT THINK IT IS AVAILABLE ALONE IT IS THE CHIP INSIDE THE TV THAT THE DLP TECHNOLOGY IS BASED OFF OF IT HAS MILLIONS ON TINY MIRRORS ON THE FACE OF IT THAT MOVE ACCORDING TO THE VIDEO AND BASICALLY YOU HAVE STUCK MIRRORS CAUSING THE SPOTS
Dec 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have white specks on screen toshiba 65 in DLP
White dots on a DLP mean that some of the tiny mirrors on the DMD board have failed and are stuck in the on posisiton and always reflecting the white light from the lamp. The DMD on this model is not available sepratley so the complete light engine needs to be replaced. The part number for the light engine is 75006693.
Aug 28, 2010 | Toshiba 65HM167 65" Projection Television
Have Panasonic DMC-FX8 set for .3M picture size to download to Ebay; however the photo properties are 640x480 but 16 Million
If the photo properties are 640x480 and 16 million colors, then you're getting .3 megapixels. The number of colors has nothing to with the picture resolution.
Apr 17, 2010 | Panasonic Cameras
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
After the lamp expired I have two red spots in the picture
There is only 2 things that will cause this and one is Dirt on optical Lense OR Light Engine is going BAD if light engine is it it will start showing more spots along with tiny DOTs and color on picture will be green and purple in different areas.
Aug 18, 2009 | Panasonic PT-40LC12 40" Rear Projection...
I want to save scanned document as a .doc using CanoScan 8400F
Scanners only see millions of dots. Unless it has software to convert a picture into a document, all documents are seen by scanners as pictures made of of millions of dots. Software is available to convert it to a Microsoft Doc format but it is very expensive.
Apr 19, 2009 | Canon CanoScan 8400F Film Scanner
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
148 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
