Question about Logitech G25 Wheel And Pedals Set
Adapter I need to get a replacement adapter power supply for my G25 cos the wiring on the one I already have is getting dodgy, anyway I can get a new one?
    Genius:
  • 2,035 Answers
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Power is not comming into the printer
No power to the printer. 1) Either the power adapter is not connected properly.Remove the power cord from main power outlet and connect it to any other electric outlet.Also at the back of the printer there is a socket where the power got get connected.Remove power wire from there too and reconnect it. 2) If the problem is not solved then there are two possibilities:-- A) The power cord is faulty and needs replacement. B) Or the printer circuit board is got short and it has to be replaced. ------------ In both the cases A as well as B you need to get the fault checked by other spare power adapter or power supply board in printer.At local printer repair shops they have this parts in spare.They will get the fault checked and let you know that which part has to be replaced.Either the power adapter or power supply board.The cost of new power adapter is near to $10 and cost of new power supply board is near to $40. -------------- One more thing i want you to check is.In your printer power adapter there is one three pin power wire is connected.That three pin power wire wire goes from main power outlet to the printer adapter.In some cases that three pin power adapter gets faulty.If that three pin power wire is faulty then the cost of that power wire is just $2.So get that three pin power wire also checked. To see how this three pin power wire looks.See the fig below:--- helpmech_1.jpg
If this wire is faulty then its not much costly. ----------- This are all the possibilities that you will have to get checked.To get the fault confirmed.Thanks.Helpmech.
Dec 04, 2010 | HP DeskJet F380 All-In-One Printer
What wires beside the sata hook to the hard drive and I changed the ac/dc cased power supply and it has one les set of wires than the origanal that could posible hook to the hard drive.
well you have the sata cable. It connects to the motherboard. You also have the power cable from the power supply that connects to the drive. As for 1 less set of wires on the power supply. Not a big deal unless you need it. Does the power supply have the same or higher output wattage as the one you replaced? Does it have sata power or just the molex 4 pin only? If it has the 4 pin only you can get an adapter for a couple bucks to convert it to sata power. Make sure the new power supply has sufficiant power for the system.
Nov 11, 2010 | Computers & Internet
My computer is plugged in but isn't charging. I've taken the battery out numerous times and have unplugged and replugged the charger but nothing is working, my computer still isn't registering that the...
This is a common problem, these adapter go faulty all the time, you need to test with a meter, or get a replacement Power Adapter... You need to take out battery and plug in adapter all laptops should work, with just the Power Adapter connected, if it doesn't then it is faulty.. well that OR laptop.. When you get a new charger you will need to leave charging at least overnight to recharge the battery.
Mar 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Is other power source needed to run this wheel besides USB on PC?
yes you will need another power adapter,usb will not be powerful enough to make it work hope this helps
Feb 22, 2010 | Logitech DRIVING FORCE FEEDBACK STEERING...
The power adapter on the back of my qosmio g35 is loose i.e. it wiggles back and forth. in order to get the power supply to work i have to "anchor" the power adapter to one side or the other else i get no...
If the pin inside the adapter is loose then at some point you are going to have take the laptop in for repair as it will shortly fail and snap.
Unfortunately you can't tighten them up but you can have a new adapter soldered onto the motherboard.
If you take the laptop to a reputable repair store they will no doubt do the job for you, don't however let them fob you off by saying that you will need a new motherboard as these day's it's not the case.
Regards.
Aug 12, 2009 | Toshiba Qosmio G25-AV513 Notebook
Connecting laptop tip to auto adapter
you may look the jack(tip) show here:
1ecfef4.jpg 1) your car adapter, the red color wire is + pole which connect to the hole of jack(tip), the black wire is - pole which connet to outcover metal of the jack(tip). that is very common.
2) your new jack: check as smae as above. usually white color connect to red color, and black to black is ground connect to outcover of tip.
then you need check again the voltage pole, the tip 's hole should be possitive "+" and the outcover metal is negative "-" pole, it is very important.
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | HP Compaq tc4400 Notebook
AC power adapter light is red what to do?
the power supply is already busted
you need to call xbox 18004699269
if you purchased the xbox within 90 days, then they can have your power supply replaced
if not you need to buy a new one
Jan 19, 2009 | Microsoft Xbox 360 Console
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
Broken ac adapter
Hi
1. The Adapter may be malfunctioned in the manner of the defects of PINS, replace first your wiring plugs
2. Warranty is not mentioning about the adapter anyway
3. The Solution is check your wire when continuity and the Power plugs has some bad conduct
Thanks,
Senthil007
sundari_changi@yahoo.com.au
+91 9789227782
India
Dec 15, 2007 | Acer Aspire 5100 Notebook
Logitech G25 Wheel And Pedals Set Logo
778 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
