I have dell inspiron 1545 which starts only under the a.c @23degree c, once it is shut down and then after few hours it stops working totally as in it is totally dead even the time gets lapsed behind when started again( under AC )
  • 73 Answers
First off, John D. you are thief, 500$ for an IT install disc is bull when you can just download them or call the companies for a copy. There is no IT version of an installation disc, only volume licensing, and you still cannot use someone elses volume product keys unless you know their domain name and company name and support contact, along with the product key, and the build number and exact specs on the systems they are deploying their copy of the disc on. Installation discs are nothing without product keys, unless you have a cracked copy of one, or access to a third party program that will void out the activation client (oobe.exe).
There are 3 real ways to bypass any stuck passwords on any XP computer.
1. Use the build in machine administrator, if it's unlocked. Seeing that administrator's can change the passwords of administrators, access to any local administrative account will yield an entry to the user account control panel applet. To see if your built in admin account is unlocked, you will need to start the computer normally. When it finishes loading, you will have one of two screens: The welcome screen, or the Windows Logon screen. If you have a welcome screen (Windows XP Home default) you will need to press CTRL ALT DEL simultaneously, and then again. CTRL+ALT+DEL release, CTRL+ALT+DEL release. The welcome screen should change to the advanced login screen, that you may already have if you have turned off the welcome screen, or if you are using XP pro, or Windows Server 2003. Next, for username type in Administrator, leave the password blank. If you can get in with this account, or any administrator account, click on start and click run. Type "Control UserPasswords2". From here, adjust the passwords of each account on the computer as you see fit.
2. Next, let's say you can't get into any administrative account, or perhaps windows is not loading all the way because your product key has expired. You will NOT be able to access command prompt in safe mode to change administrative accounts unless you can actually logon to the computer, so if windows is locked because of product key issues, don't try this. But if you can still get into a user account that is not an admin, and you need to unlock an admin, the login as the normal user and create a new account using command prompt (as a limited user you cannot do this via the control panel) and type
net user Admin2 password1 /create
this creates an account named Admin2 with a password of password1.
next see if you can make this account an admin. type
net localgroup Administrators Admin2 /add
if you get an access denied message, you will need to go to step 3. If you get a command completed successfully, the log out and go to the normal login screen. Then log in as Admin2 with the new account, and you now have admin control of the pc. Go to step 1.
3. If you cannot get into windows as any account or using command prompt in safe mode or if windows is locked with a bad product key, you can use third party software to adjust the Admin Password, or to adjust the microsoft oobe activation client, so that you can regain access. My suggestions would be to use linux boot disc, (which you can put on a CD, floppy, or flash drive) and as long as BIOS is configured to accept a boot order with one of these devices before the harddrive, then you are good to go. If not, you will have to go into BIOS to change it. Type F1 or F2 at startup to gain access to BIOS. If there is a BIOS password, and you don't know it, you will have to reset BIOS using the reset jumper on the inside of the motherboard. Look that up on google for more information.
4. If all else fails, and you cannot get in, you will have to settle for reformatting. This will clear all user data and files previously on the computer though, so save whatever you can before hand. Then, on another computer, download a copy of an installation disc for Torrentz or piratebay and burn the ISO to a disc using IMGBurn or nero, or any of those other hokey ISO burning programs. Then, place the disc in the computer you want to reformat. When it says "Press any key to boot from disc" (during the normal boot) press a key, and wait for the OS to load the WINDOWS Setup Menu. Follow the onscreen instructions to reformat the harddrive and reinstall windows. If it asks you for the current admin password you are doing something wrong. Make sure you are not trying to repair windows, or install windows onto the already made partition. This will ask for a password. You need to press D to delete the partition. Delete all partions on the drive. L to confirm the delete. Then once your disc is empty, press enter to reinstall windows and reformat, etc. Follow the directions on the screen.
Posted on Sep 15, 2010
Dell Inspiron 1545- Google Chrome & battery problems.
Your Google Chrome glitching is due to needing more memory. (if you have a lot of add-on, I'd remove some of them and see if that helps some)
On the battery issue - your battery is rather old, and needs replacing.
Mar 17, 2013 | Dell Inspiron 1545 Notebook
My inspiron 1545 types two letters at once
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
Aug 15, 2012 | Dell Inspiron 15 1545 Notebook
Dell 1545 will not power up
SOUNDS LIKE A BAD MEMORY STICK
Dec 26, 2011 | Dell Inspiron 15 Laptop
OmLaptop restarts after being shut down Its a Dell 1545
Hi 1940miker...
Try this solution to your problem
Your computer is set up by default to auto start when a problem occurs.
The computer is configured to automatically restart when Windows stops responding.
To view this setting, follow these steps:
Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
Under System Failure, view the Automatically restart check box.
If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Please take time to rate me
Sep 04, 2011 | Dell Inspiron 1545 Notebook
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
Hello, my brand new (2 weeks) DELL 1545 laptop is going into hibernate/sleep mode, 10 times in the past 1 hour 1/2???? It is NOT shutting down, just have to turn the power button on and all is back to...
goto the control panel - power options and see what you have set there for sleep mode, under the powerplan - often it can be set on a couple of mins when using battery change the setting to longer
Sep 28, 2010 | Dell Inspiron 1545 Notebook
My Inspiron 1545 laptop will let me get to the login point, them the welcome window just stops. It sometimes just goes back through the same procedure until I enter my password, and thats it! How can I fix...
Please press F8 several times during start up. When computer gives you few options of startup choose Safe Mode. Once in Safe Mode go Start----->All Programs---->Accessories------>System Tools------>System Restore. When you get there choose last date when system was working properly and restore to this point. I hope this helps and good luck.
Apr 28, 2010 | Dell Inspiron 1545 Notebook
Problem with a Dell Inspiron 1545
There is an spot under the computer that you can open to access the memory ram, once there just remove them and put them back in..try that
Feb 26, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
