Question about Crosley CDE6000 Electric Dryer
I have a cde6000w. running fine and just quit. dryer very warm to touch. lint trap was clean. duct was clean also. no blown fuse either.
  • Jennifer Turner
    Jennifer Turner Sep 15, 2010
    Is the unit running through it cycles? Or attempting to run through any? Could be a timer issue, or it could also be a breaker.
  • 23 Answers
Is the item cycling through any of the timer settings? IF so you may need the timer, Timer part number is a 53-1810,
http://www.searspartsdirect.com/partsdirect/part-model/Crosley-Parts/Dryer-Parts/Model-CDE6000W/1502/0151200/M0406027/00001?blt=06&prst=&shdMod=
Posted on Sep 15, 2010
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Tip
When to Buy a New Dryer or Fix Old One?
If your old clothes dryer is not working well, how do you tell if it's time to replace it?Here are some things to check before you set it on the curb with a"FREE" sign.
If it still turns on, runs a proper cycle, doesn't make a lot of squeaks and groans, and your clothes are at least attempting to dry, then check the following before you decide to replace.
1. Check and empty your lint trap before each load. If airflow is restricted, your dryer will need longer to get the job done. A clean lint trapwill allow for maximum intake air to the dryer blower.
2. Check the exhaust duct work for lint buildup. If the 4" duct work that carries your warm, moist, lint-laden air to the exterior of your home is blocked with years of lint and moisture, chances are pretty good your dryer is taking longer than it should to get your clothes dry.
  • Disconnect the dryer power cord (and gas line if a gas unit), slide the dryer forward far enough to access the 4" duct work clamp at the back of the dryer. Disconnect the duct work at the dryer and separate to inspect both in the dryer exhaust duct and the duct work as well.
  • Remove all built up lint. You may need to access under the floor, or in the crawlspace, or basement to get at all the areas that lint may be built up. Remember that when there's an elbow chances are pretty good there's lint in there, so take the time to separate the duct work where needed to give it a thorough clean out.
  • Long straight sections of duct work can be easily cleaned by using a Webster-style pole brush.
  • Clean the exhaust duct of the dryer but be careful not to damage anything inside your dryer
  • Reconnect and turn the dryer on air fluff to blow the rest out.
3. Remove lint build up from inside the machine
  • Turn power off again
  • Remove the front cover of your dryer
  • Remove the front drum support/air duct from the front of the dryer
  • Carefully vacuum the lint out of the dryer with soft brush attachment on your vac. Be careful not to damage any igniter or electrical items.
  • Clean the inside of the lint trap duct of sediment/ buildup
4. While you've got it open replace the drive belt and check the pulleys.
If this improves your dryer, hang onto it for a while longer! Most times dryers just need a good cleaning and the exhaust duct cleaned. If you're not satisfied with the results, take it to the curb and recycle it to another family.
on Dec 07, 2009 | Dryers
Crosley cde6000w. was running fine, quit while drying clothes. machine was very warm to touch. still had power to control knob, buzzed when turn knob to end of cycle. let machine cool down and still will...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 17, 2010 | Crosley CDE6000 Electric Dryer
Roper electric dryer keeps blowing thermal fuse. motor will not run when this happens.it is bypassed for the time being,but want it fixed immediately. Did clean completely dryer lint trap and air duct to...
Remove the lint chute and give that a good cleaning wash it and the filter out1f161fc.jpgCheck and see if the element is shorted to the frame. That will blow the fuse too.
Sep 03, 2010 | Roper Dryers
The cycles have stopped heating. We have replaced the thermol fuse twice now in two weeks. Noticed when I touch the button to start a cycle, the readout is saying to check filter. Where is that? I'm...
Go outside and look at your flapper valve. Here is another news flash the lint filter can be clean but the air ducts in the dryer can still have lint build up in them. Pull out the lint trap also then using a flaishlight look underneath and around the lint trap area for lint build up. If you don't see anything there remove the rear vent hose and look both into the dryer and into the vent hose. Most likely you find either a kinded vent hose or lint buildup somewhere other than the lint trap itself. If you do find the source just do not use anything sharp to attempt to remove the lint. A bent metal coat hanger or a very large zip / spot ite works great for this task. Hopefully this will resolve your problem. If not post back and we can go from there.
Jan 14, 2010 | Dryers
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
My dryer is blowing lint out through the vent outside, I clean my lint trap every load, but it still sends lint outside
this is normal for lint to blown out the ducting because not all the lint will be collected on the lint filter when you remove the filter some lint may fall of down into the duct housing.there is nothing ot worry about
Sep 19, 2009 | Samsung Dryers
Dryer Run too long
MAKE SURE YOUR LINT TRAPS AND DUCTS ARE NOT PLUGED.EASY REPAIR.YOU CAN DO IT.
Jan 16, 2009 | Maytag PYE2300AY Electric Dryer
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Blown thermal fuses
I would think not. The MAIN cause of that fuse blowing is lint build up. Turn the dryer on and put your hand on the outside of the vent duct. Is the air blowing hard? If so, you will probaly be ok, if not maybe your blower wheel needs to be replaced...
Dec 15, 2007 | Whirlpool LER5636P Electric Dryer
Crosley CDE6000 Electric Dryer Logo
144 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
