Question about Watches
I have a Pulsar w861-x002. The battery went dead, so I took the watch to a jewelry store (that also sells Pulsar watches). They replaced the battery, but now the time/year/and everything else cannot be set. The jewelry store told me that they could not figure out how to set the time and told me to look in my manual. I looked in the manual and followed the directions to do a total reset (which I have done several times) and STILL nothing can be set. The watch will keep time, but I cannot set it to the correct time. I don't know what to do, but I think something else needed to be done when they put in the new battery. Any suggestions?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
I replaced my battery too...same watch same ugly condition where you can't set time nor does the light work.
I do know what the problem is: there was an ultra small copperish spring...about 1/6 the size of the other little wire spring that you have to short with twizers to reset time. Anyway, I lost this part...and even if I found it, I wouldn't know where it goes. I came on-line to find where the missing part goes...but everyone has the same issue as me. any jeweler would loose this parts just like me...it's the master contact the enables power to all the side pushbuttons
Posted on Jun 24, 2011
  • 8 more comments
  • mmlars38 Jun 24, 2011
    Ok, just fixed my W861-X002 watch...found the small hole in the plastic where it needs a little spring to make contact with the metal backing plate that activates (powers +) the buttons. Without this little spring contact you can never change your time. any jewler will misplace this part..they can't see it. If anyone doesn't want to spend any more money to fix their watch...you can send me your X861 watch (w/ new-working battery)...I'll fix it (replace missing part) clean len/s and ship it back to you for free...integrity assured. Ship to: "Free X861 Watch Repair" 2224 Merrimac Lane. Lancaster , Texas 75146
  • richard_g559 Jul 27, 2011
    What guarantee do I have that I will get it back? I will gladly pay to have it fixed.
  • mmlars38 Jul 28, 2011
    Because I know I will I wouldn;t do that...I'd feel bad. I have extra batteries for that watch...as long as you accept a small percentage...of failure...I'll always send the watch back..with a new battery. I'm just helping the general populous...if things are tight financially. I recommend a trained professional to replace that battery.
  • karatehero Aug 18, 2011
    Just curious if mmlars38 still fixes these watches? I had my battery changed, and now the numbers won't reset either. You still doing that?
  • mmlars38 Aug 18, 2011
    yes, i'll take a look at it...and fix...no guarantees, if they shorted it (blown)...but it sounds like they misplaced the little contact spring to set times/dates....i'll send it back either way.
    Well, that works for me. Its not serving me any use broken. I will send it to the address above? How much $$$ do you want to fix it? Pulsar wanted to sell me a whole new watch........
    If all goes well, I will post here that you serviced it and returned it successfully. I see that Richard_G was concerned about it....
    Thanks in advance!
  • WooSung Chung
    WooSung Chung Nov 25, 2013
    where do you insert the spring on W861-X002? i might have it in a wrong spot and i don't have the alarm sound
  • mmlars38 Nov 25, 2013
    You're welcome Karatehero...it was fun! WooSung...if your watch works, keeps time, I think you have the spring in the correct location, I think you don;t have the alarm sound because you're not "able" to set the alarms, and you're not able to set the alarms due to the entire watch "snap together" procedure, extreme care must be taken or else the push buttons will not work. I think your alarm button might not be working or else you did not short the correct pins and reset the watch before battery install. I do think you have the spring in the correct location. could the the shorting pins reset or the snap together procedure.."not seated" correctly. That's all i know w/o the watch...but if it's working...do you need the alarm? regards, Mark
Now we know how Charlie Brown felt. My watch has sat idle for several months after the battery died. Today I decided to change it. I also lost the little spring. The battery is my watch is a generic 2025. The case screws are stainless steel and thus not magnetic. I also read the directions and to no avail. However, I took a sewing needle and 'poked around'. Somehow I got it to work. I think it was this..If you are looking at the back of the guts of the watch with the LED switch on your left, just to the right of the battery is a small plastic 'button' that holds the battery in position. Just below that is a lever that looks like it is contacting the side of the battery. I can slide a piece of paper between its contact and the battery so I took my might sewing needle and pushed it against the battery and it works! I guess these two points are the ones you are supposed to 'short with the tweezers'. Pain to set but......I like the display.. which you should clean with a microfiber cloth and a bit of breath prior to assembly...should you have trouble with the case screws not staying on the screwdriver point apply a tiny amount of white glue and they will stay put. Good luck
Posted on Mar 19, 2013
Well, I sent my watch to mmlars38 and I am amazed at how it came back. It works great, and all the buttons work again. I'm amazed at how fast it got here-in like 3 days it was back qt my place. Awesome!
So, thanks mmlars38, feel free to call upon the karatehero if you ever need anything! I owe you one huge!
Posted on Sep 13, 2011
My mother has a fifteen year old Pulsar Y480-5730 that doesn't run anymore. Any recommendations?
Did you check the watch battery? Pulsar watches run a long time! If a new battery does not start it up you can take a can of air and just squirt a little in the area where the battery goes (very gently) to blow out any dirt then install the battery and put back on. If it is still not working you need to take it to your local jewelry store to have an estimate for repair, usually 60.00 to 80.00. I hope this helps!
Sep 18, 2011 | Pulsar Watches
Time cannot be set on my pulsar w861-x002. I see a post for the same problem but no answer?
I do know what the problem is: there was an ultra small copperish spring...about 1/6 the size of the other little wire spring that you have to short with twizers to reset time. Anyway, I lost this part...and even if I found it, I wouldn't know where it goes. I came on-line to find where the missing part goes...but everyone has the same issue as me. any jeweler would loose this parts just like me...it's the master contact the enables power to all the side pushbuttons...w/o it you're dead in the water. best wishes, mark
Mar 14, 2011 | Watches
HOW TO REPLACE BATTERY.
eco-drive watches have a special battery, this is something i that will be hard to find, but maybe you might get lucky online. Bring it to a jewelry store that sells them and save youself the trouble on this watch
Nov 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
I can't open the back of my watch to put a battery into it
If you don't have the right tools don't even try - you'll risk damaging your nice watch. Instead, take it to a watch shop or jewelry store (Sears does it too) and let them do it with the right tools, correct battery and - very important - a new gasket to keep it water resistant. Cost for the battery replacement is about $8.
Apr 28, 2010 | Seiko Pulsar Europa Ladys Size PXQ495...
How to set the time on a pulsar W861-X002
go to acash.com. I put a scanned manual for my W860 up there.
Oct 20, 2009 | Pulsar Watches
Cannot get the back off a womans pulsar watch
some are twist of which u need a special tool.. dont take it to walmart, they are only a dollar or 2 cheaper then a jewelry store
Oct 06, 2009 | Pulsar PPG672 Ladies
Dead battery on nixon insider watch!
The insider has not one, but FOUR batteries. I took it to my local jeweler for replacement and the watch never worked the same again. I suggest you return to Nixon for battery service.
To Nixon's credit, their warranty dept. replaced my watch after trying to fix it.
Dec 12, 2008 | Nixon Insider NIX0033 Wrist Watch
Watches Logo
3,210 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
