Question about Nikon Cameras
Nikon d-90 keeps reading out 'err'
Many times in the past few monhts, when i starat to take a pic, the word reads out 'err' and the shutter locks up, turns black, and I take out the battery and replace it, and it's o.k. again. the battery is fully charged and this sometimes happens only inside, it seems to have something to do with the flash setting. I have the dial on he lleft set on auto and I can't remember how to set the flash, I have lost my manual and wolf camera, can't figure it out and/or can't get it to 'err' for them,....
emily in georgia
The "ERR" error message is a sequence failure and most common problems are shutter, aperture control or sequence motor drive system. When the problem repeats frequently, it will increase until total camera failure. Cameras in need of epairs should be sent to a Nikon Authorized Service Center like Southern Photo in Miami. Lots of repair information on all types of cameras can be found at http://blog.sp-ts.com so check it out for more repair information.
Posted on Jul 04, 2008
When I turn on nikon d80 err flashes
The Nikon D-90 users manual says on page 256 that the ERR message indicates a camera malfunction and that it can be cleared by releasing the shutter.
I've found on my D-90 that the only way I can get the shutter to release is my turning the camera off. When I turn it back on the ERR message is gone and the camera functions as it should.
Occasionally, I have had to remove and reinstall the battery to make the camera turn off but this happens only rarely.
The users manual says if the condition occurs frequently or persists that you should contact a Nikon authorized repair center. I suggest that you contact Nikon tech support at www.nikon.com to see what they suggest. I think this information would apply to the D-80 as well.
May 04, 2014 | Nikon D80 Digital Camera with 18-135mm...
Err message displays, won't take photo
Feb 16, 2014 | Nikon D70s Digital Camera
Nikon d60 will not take picture
The users manual says if the condition occurs frequently or persists that you should contact a Nikon authorized repair center. I suggest that you contact Nikon tech support at www.nikon.com to see what they suggest. I think this information would apply to the D-60 as well.
Feb 06, 2014 | Nikon D60 Digital Camera
My 4 months old nikon D90 shows ERR. Been trying for the past 2 days. Can you help?
Try removing the lens. Turn it on. Press the shutter a few times. Re-attach the lens and try it.
Apr 04, 2011 | Nikon D90 Digital Camera with 18-105mm...
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
Err
The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Apr 05, 2010 | Nikon D80 Digital Camera with 18-135mm...
Purchased the D90 with 18-105 kit lens yesterday. Took it home started playing with it and after abt 5 clicks err came up on the screen. Consulted the manual talked about shutter release but if the problem...
According to and directly from Nikon:
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
  1. Remove all accessories from the camera.
  2. Install a freshly charged battery into the camera.
  3. If your Nikon camera offers resets such as the two-button reset or a hardware reset please follow those instructions provided in the product manual.
If these steps do not resolve the Err message we recommend having a Nikon Authorized Repair Technician evaluate the Nikon camera. Click here for repair information.
Nikon Imaging Products Support Page:
http://imaging.nikon.com/products/imaging/support/index.htm
Oct 12, 2009 | Nikon D90 Digital Camera with 18-105mm...
NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Sep 25, 2008 | Nikon D2H Set Digital Camera
Cameras Logo
129 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
