Question about Emerson Microwave Ovens
A dinner I was cooking in the microwave sprayed on the inside like an entire covering and I can't remove it.
  • 490 Answers
Ahh, I hate when that happens!
Put a microwave safe bowl with about 3 cups of water in the microwave and heat on high for about 4 minutes or until boiling well. leave it sit for several minutes and then wipe out the inside of the machine with a damp cloth or sponge. You are not alone:)
Farmerbear at FixYa.com
Posted on Sep 15, 2010
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
Why does my microwave arch at the wave guard
Typically most arcing in a microwave is caused by food splatter. A microwave cannot tell the difference between what is on a plate or on the wall or ceiling. Every food particle in a microwave will continue to cook until it turns to carbon and will attract the microwave energy and focus it to that spot and the unit will arc. Thorough cleaning of the entire microwave cooking cavity and removal of any burn or soot mark will commonly stop the arcing. If your microwave has a painted cavity, you can even use some very fine sand paper to remove any burn mark. Always cover what you are warming and really keep the inside of the microwave clean. If your wave guide cover is made out of the Mica board, and If it has gotten wet from cleaning or from splatter, it must be replaced. You can either order a new one or order a sheet of the mica board and cut out a new one yourself. If the microwave is arcing in the waveguide, generally the unit will need to be replaced. One quick test to see if the unit will work is to remove the bad cover and place a small container of water in the unit, run the machine of a minute or so and see if it still arcs. If it does, the arcing is in the waveguide area, if not it may have just been a problem with the cover. You can run the unit without the waveguide cover in place, it is only there to prevent splatter from getting into the waveguide, so removing it to test the unit is ok. If the area inside the wave guide shows signs of soot and arcing. You can try to wipe that out with some alcohol or lacquer thinner and then try it again. Good Luck.
May 15, 2014 | Magic Chef 1.6 Cu Ft Countertop Microwave...
This is now the 3rd GE to die on me in 10 years. Model is PEB2060dm1ww. Its a built in microwave Last night my soon cooks his dinner OK. When my wife went to cook her artichoke.. all seemed fine as the...
if out of warranty you can try a simple "fix" . some microwaves are made with a simple fuse on the inside of casing- should be able to remove cover with 4-6 screws and then locate fuse- DO NOT TOUCH ANYTHING ELSE! If in doubt replace the whole thing.
PS- if dusty inside ,use canned air(for computers or cameras)
May 02, 2011 | GE Microwave Ovens
Its a gas oven is it safe to cook the dinner while i wait for a new one
It depends entirely as to the reason for buying a new cooker.
Was it safe? Was it broken? Did it no longer work? Were you just wanting a change?
You have not disclosed any of that information and therefore I am unable to offer an opinion. Sorry
Jan 23, 2011 | Microwave Ovens
TURNTABLE AND LIGHT NOT WORKING
It will cook entirely different ... you will want to turn the food occasionally to assure complete cooking.
You probably have a burned out lamp ... look inside for an access panel. If none, you will have to remove the cover. There are probably 8 to 10 screws and they may be Torx - Torx is a star shape, available at auto parts store of Sears (K-mart).
Once inside - DO NOT TOUCH THE SILVER CAN - LETHAL.
Find the lamp, check it out. If burned, get a replacement at your hardware or appliance store or maybe at a Big Box store.
I hope this helps you.
a
Sep 26, 2009 | Magic Chef MCD990W Microwave Oven
Low power when cooking. Takes twice as long to cook a frozen dinner as what the package states
Check the power output. Most are adjustable. With the microwave on, and cooking something, see if it is on 100%. If not, adjust it with the keypad.
Regards, --W/D--
Aug 01, 2009 | Magic Chef Microwave Ovens
GE microwave
If the mocrowave still working, I wouldn't worry about operating it. If you want to have some peace of mind you can buy the paint and do it yourself. Go HERE to get the paint that is specially for microwaves use.
Feb 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
