Question about Acer Aspire 1691WLMi PC Notebook
Acer aspire one aoa150 1691. Tryed to hook to my tv, but nothing happens. My netbook says there not even anything hooked up to the vga port. I have tryed hooking everything up with both on and off. I set my resolution on 800x600 and still nothing. My netbook still says there is nothing hooked up. Graphics properties says single display just my netbook and that i need to connect something to it to have multiple display. I should at least get something saying that my vga port is plugged up right. I have tryed everything, need help bad. Thanks.
alocenar
  • 293 Answers
SOURCE: resolution problems on notebook monitor
check your projector settings. it should be matching the resolution on your laptop.
Posted on Apr 10, 2008
SOURCE: Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Posted on Jan 20, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
Posted on May 30, 2009
  • 8 Answers
SOURCE: Need to hook up laptop to TV
If you have an HDMI port you might also have an RGB port, use your tv video source button and go through your options. If RGB option is listed you have it. It's a standard moniter port, you can use a standard monitor cable to hook things up. This will not however carry sound so you'll need a basic 3.5mm size cable that ends in an RCA plug (can be picked up radio shack.
I use this method to watch hulu.com movies on my 50" plasma tv.
Another option if you have an "S" video on both the laptop and the tv, use that with just an "S" video cable.
Other wise look for a RGB cable that converts to standard RCA stereo plugs again Radio Shack should be able to help you. You can also buy cables on eBay a lot cheaper then a retail store.
Posted on Aug 20, 2009
Bray2thaden
  • 173 Answers
SOURCE: im trying to hook up my acer aspire one to tv via
after you hook it up try holding the fn key and pressing f5... this should work... hope it helps...
Posted on Mar 07, 2010
Acer support
Use the VGA and set the TV to VGA as well.
Oct 15, 2012 | Acer Aspire One D255E13438 Netbook
What cord do I need to connect my acer notebook to the t.v for netflix
this is pretty easy. Since you're acer aspire doesn't have an HDMI out port, then you're gonna need a VGA cable to connect your acer's video signal to the TV.
This cable should do: http://www.amazon.com/10ft-Resolution-mo...
Now, since it's not HDMI, you won't get audio coming out the TV, only your laptop. But if you want audio out your tv, all you'll need is audio cable, which you can connect to the headphone jack (audio out) and then into the AUDIO IN jack on your tv.
the audio cable: http://www.amazon.com/Cables-Unlimited-A...
After this, just hook it up while your tv is turned on, switch to the VGA channel on your tv, and a window should come up on your tv asking you to configure the settings. For audio go to the control panel while the audio cable is hooked up, go to sound settings, and switch the default audio to speakers, or headphones, im not so sure what it is on a netbook
Aug 16, 2011 | Acer Computers & Internet
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I want to connect my acer aspire notebook to my tv, how do i go about doing this?
Alright didn't really know what acer model you have, but this is pretty easy, you can attach your Tv to either oneof the external source outlet on your acer and Press the FN button between your left ctrl and alt key. There should be a symbol in the F keys exm, (f1, f2 ) in which i believe acer is the F5 key... that looks like a laptop'a sqaure.... Press those two keys and depending if you have it hook up to the HDMI or VGA, just press until you find the correct port via vga/svideo/hdmi.
Jan 15, 2011 | Acer Aspire One Netbook
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
I have an Acer Aspire netbook that I want to hook to a projector. I finally got the right cord to hook it up, but it will not display on the projector screen.
One of the F keys will toggle between the Laptop Screen and the VGA output - look at the F keys and see if one has a picture of a screen often F4 / F5 - needs to be used with the FN key
FN key+ F4 Key (Or which ever key has the symbol on)
It will toggle between <laptop screen only><laptop screen and VGA output><VGA output only> Not necessarily in that order
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
Im trying to hook up my acer aspire one to tv via vga cable but cant seem to get it right.....any one know what to do?
Feb 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
Oct 09, 2009 | Acer Aspire 5100 Notebook
May 17, 2009 | Acer Aspire One PC Notebook
Acer Aspire 1691WLMi PC Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
