Question about Dell Inspiron 1525 Laptop
Have forgotten the administrator password for my computer and can only get in through guest. It will not allow me to change any settings or download anything. Is there a master password that I can use to get in?
  • Anonymous Apr 01, 2014
    only one administrator accoun and one guest. also, I have no CD slot other wise I would have already fixed this.
  • 83 Answers
    Problem Solver:
  • 5 Answers
DOWNLOAD KONBOOT CD FROM GOOGLE AND USING THAT YOU CAN CHANGE PASSWORD FOR ANY VERSION OF OS.
IF YOU DONT HAVE CD DRIVE . YOU CAN RUN IT USING FLOPPY OR BUY USB CD.
Posted on Aug 21, 2014
  • 73 Answers
First off, John D. you are thief, 500$ for an IT install disc is bull when you can just download them or call the companies for a copy. There is no IT version of an installation disc, only volume licensing, and you still cannot use someone elses volume product keys unless you know their domain name and company name and support contact, along with the product key, and the build number and exact specs on the systems they are deploying their copy of the disc on. Installation discs are nothing without product keys, unless you have a cracked copy of one, or access to a third party program that will void out the activation client (oobe.exe).
There are 3 real ways to bypass any stuck passwords on any XP computer.
1. Use the build in machine administrator, if it's unlocked. Seeing that administrator's can change the passwords of administrators, access to any local administrative account will yield an entry to the user account control panel applet. To see if your built in admin account is unlocked, you will need to start the computer normally. When it finishes loading, you will have one of two screens: The welcome screen, or the Windows Logon screen. If you have a welcome screen (Windows XP Home default) you will need to press CTRL ALT DEL simultaneously, and then again. CTRL+ALT+DEL release, CTRL+ALT+DEL release. The welcome screen should change to the advanced login screen, that you may already have if you have turned off the welcome screen, or if you are using XP pro, or Windows Server 2003. Next, for username type in Administrator, leave the password blank. If you can get in with this account, or any administrator account, click on start and click run. Type "Control UserPasswords2". From here, adjust the passwords of each account on the computer as you see fit.
2. Next, let's say you can't get into any administrative account, or perhaps windows is not loading all the way because your product key has expired. You will NOT be able to access command prompt in safe mode to change administrative accounts unless you can actually logon to the computer, so if windows is locked because of product key issues, don't try this. But if you can still get into a user account that is not an admin, and you need to unlock an admin, the login as the normal user and create a new account using command prompt (as a limited user you cannot do this via the control panel) and type
net user Admin2 password1 /create
this creates an account named Admin2 with a password of password1.
next see if you can make this account an admin. type
net localgroup Administrators Admin2 /add
if you get an access denied message, you will need to go to step 3. If you get a command completed successfully, the log out and go to the normal login screen. Then log in as Admin2 with the new account, and you now have admin control of the pc. Go to step 1.
3. If you cannot get into windows as any account or using command prompt in safe mode or if windows is locked with a bad product key, you can use third party software to adjust the Admin Password, or to adjust the microsoft oobe activation client, so that you can regain access. My suggestions would be to use linux boot disc, (which you can put on a CD, floppy, or flash drive) and as long as BIOS is configured to accept a boot order with one of these devices before the harddrive, then you are good to go. If not, you will have to go into BIOS to change it. Type F1 or F2 at startup to gain access to BIOS. If there is a BIOS password, and you don't know it, you will have to reset BIOS using the reset jumper on the inside of the motherboard. Look that up on google for more information.
4. If all else fails, and you cannot get in, you will have to settle for reformatting. This will clear all user data and files previously on the computer though, so save whatever you can before hand. Then, on another computer, download a copy of an installation disc for Torrentz or piratebay and burn the ISO to a disc using IMGBurn or nero, or any of those other hokey ISO burning programs. Then, place the disc in the computer you want to reformat. When it says "Press any key to boot from disc" (during the normal boot) press a key, and wait for the OS to load the WINDOWS Setup Menu. Follow the onscreen instructions to reformat the harddrive and reinstall windows. If it asks you for the current admin password you are doing something wrong. Make sure you are not trying to repair windows, or install windows onto the already made partition. This will ask for a password. You need to press D to delete the partition. Delete all partions on the drive. L to confirm the delete. Then once your disc is empty, press enter to reinstall windows and reformat, etc. Follow the directions on the screen. If you are using a cracked version of Windows, you will not need a product key. If you are using a normal disc, and you have a product key that works (usually on the side of the OEM machine, or on a label on the software package for ordered products) then type that in if it asks for it during setup, or after setup on the first logon when MSOobe (the activator) starts.
Any questions, or if you'd like me to outline specific instructions for you in a specific scenario, e-mail me privately at zgwin (at) zigweb (dot) net.
JAIN_IT {INDIA}
Posted on Sep 15, 2010
    Brigadier General:
  • 4,044 Answers
What version of Windows are you using? If it is XP it is possible to delete the Password files and then you can put a new password in. If it is Vista or Win 7. I haven't found a way around that problem that I can post on this sight. I will tell you that is a way to do it but I can't post that answer directly here. If you are close to a college or know someone in a college that you trust enough they can take it in to the computer lab and there is usually someone there that can assist in doing this. That's where I got my software from to handle that problem.
How do i change my password when im on as a guest windows vista
Hi
Sorry to be negative but the guest account cannot change the computer settings, only someone with administrator rights and an administrator account username and password can make such a change.
Cheers
Jan 04, 2015 | Microsoft Windows Vista Home Premium with...
Tip
How to Recover eMachines Notebook Windows Password
eMachines, as a brand-name laptop, is attractive to many netbooks users. We also call it as Acer eMachines for its developing history. We often receive letters from eMachine notebooks users on Acer eMachines password reset for forgotten eMachine administrator password. How to remove eMachines password or change eMachine password if I forgot Windows 7, XP, Vista password? Now, begin discuss the ways to unlock eMachine password.
1. Reset eMachines administrator password with other admin account
This means that we still can login our computer by accounts with administrative rights or privileges. Please never forget the default administrator, it may help much!
eMachines XP password reset from Safe Mode
A. Switch on eMachine Windows XP laptop and keep pressing F8.
B. Opt for "Safe Mode" and press "Enter" key at the Advanced Boot Option windows.
C. At login screen, choose the Administrator account and keep "Password" column blank (or input the changed password if the default Administrator account password has been changed before).
D. Start - Control Panel - User Accounts - select the account needed to change password - Change the password.
E. Input a new password, confirm the password again and then complete
Acer eMachine password removal on XP.
eMachines password recovery on Windows 7
We can recover forgotten password with built-in admin account:
A. Power on Acer eMachine computer and press the key: F8.
B. At the Windows - Advanced Boot Options, select "Safe Mode with Command Prompt" and press Enter to confirm. Then PC starts Windows.
C. Choose the Administrator account shown on the account screen, and then login windows - Administrator: cmd.exe. Input command: net user Lily abcd and Enter to confirm (Lily is the account needed to break password; abcd is the new password for the account).
D. After command finished, we can restart eMachine Win 7 laptop and login with account - Lily, password - abcd.
2. Break eMachines password with only guest account
We know that the guest account can not do more operations on a security PC. So, we have to refer to other way to retrieve the admin account for further operations.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
on Jul 08, 2011 | E-Machines eMachines Desktop PC
Tip
How to Reset Windows Password With an Standard User Account?
When you <a href="http://www.windowsloginrecovery.com/forgot-windows-password.html">forgot Windows password</a>, did you feel confused that why you cannot reset the forgotten Windows password via standard user or guest account? The answer is very simple as the standard user and guest accounts do not have rights to reset the password of another accounts. Within the three types of Windows user accounts, only the administrator account allows you to change another accounts' password. So if you want to <a href="http://www.windowsloginrecovery.com/reset-windows-password.html">reset Windows password</a> of another accounts, you need to change your account type to administrator firstly. Moreover, if you need to give a user more access to perform tasks like installing software or other system changes, you also need to change your account type.<br /><br /><span style="font-weight: bold;">Steps to Change Windows User Account Type</span><br /><br />1. Log on your Windows machine with an administrator account.<br /><br />2. Click "Start" - "Control Panel" - "User Accounts and Family Safety" - "User Accounts".<br /><br />3. Click "Manage another account".<br /><br />4. Click on the user account that you would like to change its type.<br /><br />5. On the following window, click "Change the account type" from on the left pane.<br /><br />6. Select Administrator and click "Change Account" Type to finish your operation.<br /><br />Since the standard user account turn to an administrator one, you can reset Windows password of another accounts or do other operations without limitation through control panel.<br /><br />You can change standard user to administrator only when you can log on your computer with an available administrator account. If you forgot Windows password of all administrator accounts, you'll need to reset Windows administrator password even you can access your computer with a standard user or guest account.<br /><br />Software Windows Login Recovery allows you to create a password reset disk with blank CD/DVD or USB flash drive. With the disk you can reset Windows password to be empty in few minutes. With it, you'll never be worried when you forgot Windows password. All you need to do is just three steps.<br /><br />1. Download and install Windows Login Recovery.<br /><br />2. Burn a password reset disk with a blank CD/DVD or USB flash drive.<br /><br />3. Reset Windows password to be empty.<br /><br />Now you can log on to your computer without passwords. By the way, you can reset any account's password with this software. <br /><br /><span style="font-weight: bold;">Something about Windows User Accounts</span><br /><br /><span style="font-weight: bold;">Administrator:</span> A administrator account is intended for someone who can make system wide changes to the computer, install software, and access all non-private files on the computer. Only with administrator rights you can full access to other user accounts on the computer, change other their names, passwords, and types.<br /><br /><span style="font-weight: bold;">Standard user:</span> The standard user account can help protect your computer by preventing users from making changes that affect everyone who uses the computer. When you log on to Windows with a standard user account, you can do anything that you can do with an administrator account. But if you want to install software or hardware, reset Windows password of another accounts, etc. the computer might ask you to provide a password of an administrator account.<br /><br /><span style="font-weight: bold;">Guest:</span> A Guest account allows people to use your computer without having rights to access to any of your personal files. This can be useful if you want to quickly allow someone to use your computer. A person that log on computer with guest account cannot install software or hardware, change system settings, or create a password.
on Dec 24, 2010 | Computers & Internet
Starting my laptop up
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Apr 06, 2013 | HP Pavilion dv6-1030us Notebook
Which operating system are you on ?
Windows allows you to create a guest account that is limited in terms of its ability to change settings and download content and software. At times, you may want to reset this account's password, which is easily accomplished.
Log into the system as the administrator. Click the "Start" button and then "Control Panel." Choose "Administrative Tools" and choose "Computer Management." Click "Local Users and Groups" in the left column and then "Users." Right-click "Guest" in the main menu and choose "Properties." Enter the old and new passwords. Confirm the password. Click "Next" and "Finish."
Create a secure Guest Account in Windows 7 http://content.techrepublic.com.com/2346-12843_11-459655-4.html
Feb 28, 2013 | Computers & Internet
Tip
How to Bypass Windows 7 Password?
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.<br /> <br /> Recently I met many similar questions. Are you troubled with the same problem, also forgot Windows 7 password? Well, before answering the question, you should understand what a guest account is?<br /> <br /> <span style="font-weight: bold;">What is a guest account in your Windows 7?</span><br /> <br /> The guest account in your Windows 7 only allows people to use your computer without having access to your personal files. With the guest account, you can't install any software or hardware, change settings, or create a password. Because the guest account allows a user to log on to a network, browse the Internet, and shut down the computer, you should disable the guest account when it isn't being used.<br /> <br /> Solution: After learning the definition of a guest account, you can understand it is not possible for you to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 user password </a>through the guest account. But you can bypass your Windows 7 password, with Windows Password Recovery Tool 3.0, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.<br /> <br /> <span style="font-weight: bold;">What is Windows Password Recovery Tool 3.0?</span><br /> <br /> Windows Password Recovery Tool 3.0 is professional Windows password reset software with 3 editions: Windows Password Recovery Tool 3.0 Standard, Windows Password Recovery Tool 3.0 Professional and Windows Password Recovery Tool 3.0 Enterprise.<br /> <br /> It is designed to bypass Windows domain password, Windows administrator password and user password. With this Windows password recovery tool, you can instantly regain access to your locked computer by burning a bootable CD/DVD or USB flash drive on your own. No need to reinstall computer or pay to PC experts when you forgot administrator password or domain password on Windows 7/Vista/XP/NT and Windows Server 2008(R2)/2003(R2)/2000.<br /> <br style="font-weight: bold;" /> <span style="font-weight: bold;">How to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> easily?</span><br /> <br /> Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.<br /> <br /> Step 2: Burn bootable CD/DVD or USB flash drive.<br /> <br /> Step 3: Set your locked computer to boot from CD ROM or USB.<br /> <br /> Step 4: Choose the installation path of Windows, and enter the ID of the path.<br /> <br /> Step 5: All Windows account user names will be displayed for you. Enter the ID of a specified User Name to remove its account password.<br /> <br /> Step 6: Enter y to confirm and continue your operation.<br /> <br /> Step 7: Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.<br /> <br /> Step 8: Take the burned USB flash drive out of computer and press any key to restart your computer when you enter n to finish your operation.<br /> <br /> The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after <a href="http://www.windows7password.net/"><span style="font-weight: bold;">Windows 7 password reset</span></a>.
on Nov 22, 2010 | Computers & Internet
Tip
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I bypass Windows 7 password with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.
Solution: After learning the definition of a guest account, you can understand it is not possible for you to bypass Windows 7 password through the guest account. But you can bypass your Windows 7 password, with Windows Password Breaker, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.
What is Windows Password Breaker?
Windows Password Breaker is professional Windows password reset software with 3 editions: Windows Password Breaker Standard, Windows Password Breaker Professional and Windows Password Breaker Enterprise.
How to bypass Windows 7 password easily?
Step 1: Download and install Windows Password Breaker Professional.
The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after Windows 7 password reset.
on Nov 18, 2010 | Computers & Internet
Want to remove windows administrator pass word
Usually, there are very 2 easy ways to reset Windows password after it is forgotten.
One is: use another administrative user on the Windows computer to change or remove the already forgotten Windows password.
And the other way to reset password Windows: use a previously created password reset disk. Some people may still not know how to create such a disk.
Below are the detailed tutorials:
http://www.windowspasswordreset.net/article/reset-password-windows.html
Feb 09, 2011 | Computers & Internet
Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook: administrative log in password was forgotten...
There is plenty of software for windows password recovery available online. You can follow this 5 easy steps to reset your forgotten password:
1. Enter a computer that can link to Internet. Download Windows Login Recovery and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset your password.
5. Now login Windows and set a new password.
May 16, 2010 | Acer Aspire 5610-4648 Notebook
Windows vista admin password
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jan 25, 2008 | Microsoft Windows XP Professional With...
Dell Inspiron 1525 Laptop Logo
278 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
