Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
I have a Viking Professional dishwasher that is about 5 years old. When I use the delay function, it seems to delay starting the dishwasher for about 12 hours. Is this correct?
  • 901 Answers
Please check the user guide. There may be settings available like sleep timer in TV sets.
Posted on Sep 15, 2010
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
I have a viking dishwasher that is not a year old yet. I start it and within 5 min the lights start blinking on it, so it stops?
can you please confirm which light is blinking.
Does it take in water before it stops?
Refer page 34 and 35 in this manual once you check which light is flashing.
Hope this helps.
May 15, 2011 | Viking VDB450 Dishwasher
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
There is a device called the Water Div valve which directs the water to the arms, this would appear to be defective
Feb 01, 2009 | Viking 24 in. Professional Series VUD141...
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Viking Dishwasher Timer Dial not advancing
The timer has given it up.  The motor has probably stopped working or the gears are jammed.  You'll need to obtain and change the timer.  Generally, there are face mounted screws that may or may not be behind some covers.  Remove them to get to the panel that holds the timer.
Nov 20, 2008 | Viking 24 in. Professional Series VUD141...
Link doesn't seem to have any information on Viking dishwashers.
sorry for the delayed response, you can click on the request more assistance button or repost the problem, I don't remember what the button says but other solutions have been offered by other experts.
expert toddg has suggested that there is a 5 year warranty, is it over 5 years old?
if you don't see hes solution just click on the repost problem a few times.
Jul 31, 2008 | Viking 24 in. Professional Series VUD040...
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
163 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
