Question about Kyocera FS-1030D Laser Printer
Printer powers up but toner light stays on, other lights circulate. Have replaced cartridge.
    Brigadier General:
  • 3,917 Answers
Hi
If your toner light stays on you have two choices. On the left side of the toner cartriage is a little switch, turn it all the way counterclockwise and this tells the toner sensor that there is plenty of toner. The light will go out and you can start printing again. Also, on each end of the toner cartridge there is a little hole, about the size of a pencil point. Cover these with black electrical tape.This will sort out your problem.
You can also try the bellow instruction:-
Turn the power unit off then open front cover,then press and hold GO and turn power on ,when all 3 lights lights up release and press GO twice now all lights will turn steady now with all lights solid, press GO 5 times the ready light will go red.Now close door and you're all set
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 15, 2010
One of the indicator lights stays on
HP LaserJet 2550L Printer panel indicates 4 LED's for 4 toner cartridges, 1LED for the Drum unit. one LED for the power on button. one of the cartridges or the Drum unit has a problem, it indicates from the lights shows on or flashing. By referring to the indication lights you can diagnose the problem contains in one of the cartridges or the drum unit. By replacing the appropriate item you'll be able to make the printer to the working condition.
Jan 24, 2013 | HP LaserJet 2550L Printer
Gear train on toner cartridge locked up and caused a red light on printer to come on. Replaced with a new toner cartridge but red light stays on and it will not print.
may be it will be the problem that some sensor of printer like exit sensor or sensor which r displayed under the toner cartridge will be in busy condition
Nov 22, 2010 | Samsung ML2251N Laser Printer
Toner light comes on and status light is red after replacing toner cartridge.
Oct 12, 2010 | Brother HL 5250DN Laser Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
After replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Apr 02, 2009 | Dell 1710 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Mar 17, 2009 | Brother HL 5250DN Laser Printer
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
Kyocera FS-1030D Laser Printer Logo
177 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
