Question about Fujitsu AMILO PC Laptops
Some of the keys don't work. But they'll work if I press other key first then the key I need. This include the Return key. All the keys work if I use a USB plug in key board. Is there any botton I should press to correct this problem OR the key board needs to be fix?
    President:
  • 2,291 Answers
The key board need to be fixed
Posted on Sep 15, 2010
Where can I find a replacement chuck key for a Delta 11-950 bench press?
No you don't have to buy Delta's chuck key. MOST drill press chuck keys are very similar but if you do order another companies key and it doesn't fit, you may be stuck with it. If you have a local tool repair center that carries keys you can try one and if it don't work, return it.
The Delta part number for your chuck key is 1313104. It is avaliable from Dewalt (they own Delta) on their service website at http://servicenet.dewalt.com. You can also get it at aftermarket sites like www.ereplacementparts.com for only $11 plus shipping.
Sep 15, 2012 | Delta Machinery Drills
How do you remove the tab set
You probably have the L. margin set there. Return to that point, press but don't hold the MAR REL key, backspace to desired location, press L. MAR key.
DickyO
Oct 24, 2011 | Nakajima AE-740 Typewriter
Is there a guide of how to use this calculator i do not under stand how to work this
Here's a link to a pdf of the manual. The basics are that you have 12 white keys near the bottom, which include the 10 digits, a decimal, and the negative sign. On the right, you have the four operating keys, division, multiplication, subtraction, and addition. You also have the Enter key which will solve the expression. You'll notice that the buttons have blue and green lettering above them, and those are for the 2nd and alphabet functions. So if you press the 2nd key on the top-left, then the on key in the bottom left, then it'll turn it off, because it also functions as the off key. The Alpha key is used to input letters which are in green above each number. Good luck!
Sep 01, 2011 | Texas Instruments TI-84 Plus Calculator
My Settings/Advanced/Displays, don't show, there is no setting to use any ex. screens I have 2-Inspiron 8500s my other one shows the setting display but one don't can you tell me what to do to get...
LAPTOP OR NOTEBOOK COMPUTERS HAVE A KEY ON THE KEYBOARD IN THE LOWER LEFT SIDE THAT HAS A "Fn" MARKED ON IT, SHOULD BE BY THE CTRL KEY. PRESS THIS KEY ALONG WITH AN "F"KEY, NORMALY F5, ( HAS 2-BOXES WITH A DIVIDER LINE), WILL CAUSE YOUR SCREEN TO GO BLANK AS IT IS NOW SENDING THE VIDEO TO AN EXTERNAL MONITOR. PRESSING THE 2-KEYS AGAIN WILL APPLYTHE VIDEO TO BOTH MONITORS, THEN PRESSING BOTH AGAIN WILL RETURN IT TO YOUR LATOP ONLY.
Aug 24, 2011 | Dell Inspiron 8500 Notebook
I forgot my security code can u help me to fix it...as soon as possible
Hey welcome to fixya. Hope u 'll be fine
  • Fixya provide u explained and good solutions Just Open the following link and follow the steps carefully to know your code.
  • For link
    Just "Click Here"
If u not want this then u can also format your cell
u don't need to unlock, for format your cell just follow following procedure
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone 'll format completely
Note :all your data will be delete in the process of formatting.
select any solution u want
I hope this solutions will work and helpful 4 u. Best of luck
Please do rate if it is helpful
Go to the below link and you can confirm that the above code works, its include asker's testimonial too Click Here If more help, I am here to help Thanks & Keep using fixya
Jul 01, 2010 | Nokia 3110 Cellular Phone
My laptop powers up but now it will frequently
This folder means your Mac can't find a "Startup Disk'. Try holding down the "option" key at startup.
If you see a drive, select it and click the arrow.
If you have an iBook or Powerbook try holding down the "X" key at startup.
If neither of these options work you may need to repair the disk. To do this do the following.
Turn on your mac, immediately after the tone press and hold the command + S keys until the computer shows a black screen with white text.
Once this is finished loading you'll be at a "command line"
Type the following exactly as shown, including spaces.
/sbin/fsck -fy
Now press the return key.
If any repairs were made, repeat entering the command and press return.
Do this until no repairs are made.
Now type the following exactly as shown.
reboot
And press return.
If your computer reboots and makes it to the login screen then congratulations. If not you can try this as well.
Start up your mac and BEFORE the grey screen appears press and hold the following keys at the same time.
command + option + p + r
hold these keys down until the computer restarts and you hear the startup sound for the second time, then let go of the keys.
Other than that you may need to take it to someone to be repaired. hope this helps.
Feb 13, 2010 | Apple Computers & Internet
I just got my oil changed on my 96 Aurora & the computer still says "change oil". How do i fix that?
To reset your maintenance reminder system (even if the light hasn’t come on yet), you’ll need to turn your key to on (but don’t start!) and make sure your odometer is on TRIP A. Then key off. Press and hold the Odometer/Trip button. While holding down on the button, key the ignition to on (Don’t start the engine!) The display panel will count down from “------“ to “-“Continue pressing the button until the Trip A is displayed. After this step, you are done.
Oct 14, 2009 | 1996 Oldsmobile Aurora
How do you get rid of the oil service light on a 85 528e series Bmw
Oct 09, 2009 | BMW 528 Cars & Trucks
How do i reset oil change ligth on 2006 hummer h3 after oil change thanks from moises
Sep 30, 2009 | 2006 Hummer H3
Screen orientation
Good morning pimelles, Somewhere on your PC there is a program that is capable of rotating your screen through a key combination. I?ve read some accounts that claim this feature is built into Windows XP but I think it is only included on the tablet version of Windows. At any rate the typical combination is holding the ?Ctrl? and ?Alt? keys down and pressing the up arrow key. That should return your screen to the normal orientation. If that doesn?t work let us know your video card manufacturers model number and please don?t forget to rate the posting.
Jan 05, 2007 | LG Philips 13.3 TFT LCD Screen
Fujitsu AMILO PC Laptops Logo
255 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
