HP officejet J5750 "turn power off and then on" keep coming back. Did turn off/on. How to reset?
713printech
  • 32 Answers
SOURCE: missing printed lines form HP Officejet J5750 All in One printer
The cartridges may need to be cleaned by the printer. Check for this option on your user's manual, they will usually refer to it as a nozzle check/clean.
If the cartridge is clogged and does not unclog replace the ink cartridge. Contrary to what people might think these cartridges have a shell life and can be faulty out of the box.
Posted on Nov 19, 2008
myjosh007
  • 530 Answers
SOURCE: my hp officejet j5750 does not copy
hi im josh in cebu phils.try my solutions
.tt1 {font-size: 10pt;} If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
tip_icon.gif Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
Problem: Your Printer Prints, but the Fonts Aren't Correct If you create a document on a PC with one set of fonts installed, and try to print it on another PC with different fonts installed, you could be in for a real surprise! Windows will try to "match" missing fonts, but quite often the match leaves a lot to be desired—resulting in different line lengths and page breaks than what you had originally. Your options are to install the missing fonts on the PC you're printing from, or change the fonts in the document in question. (A word to the wise: stick to common fonts such as Arial and Times New Roman if you think you'll be sharing a document on multiple PCs.)
Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge.
Problem: Paper Jams in Your Printer It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems.
THE ABSOLUTE MINIMUM
  • Most printer problems are caused by a bad cable connection, a misconfiguration in Windows, or a bad or outdated print driver.
  • All printers need periodic maintenance; make sure you regularly change toner or ink cartridges, clean the paper path and feed, and—if you have an inkjet printer—use the cleaning option to clean the ink jets and cartridge.
  • If you're having trouble printing graphically intense documents on a laser printer, you might need to add memory to the printer or simplify the documents.
  • Lightweight paper can cause unexpected paper jams; use a better grade of paper to keep things running smoothly.
  • good luck friend
Posted on Mar 05, 2009
websnail
  • 419 Answers
SOURCE: HP Officejet Pro L7580 says I unplugged it, but I didn't!
It sounds like the printer is suffering from some kind of hardware failure which may have been caused by a power surge or similar.
I've never heard of this particular problem and I doubt HP will have either but my advice would be to contact HP support and see if they can provide more information or advise you better.
Unfortunately if my guess is right, there's really not a lot you can do except replace the printer with a new one.
Posted on Mar 15, 2009
  • 62 Answers
SOURCE: officejet J5750 won't scan. Error message on
did you check this? you probably did but better post it anyway http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Posted on Apr 14, 2009
  • 2678 Answers
SOURCE: how can i override and disable or bypass
You can't.
Posted on Apr 19, 2010
Have a Costco refill (74XL) for my J5750, that was working fine. got "cartridge on right needs replacing" message. took it to Costco and told the cartridge is almost 75% full. Is there a way to reset/
It could be possibly defective cartridge or it is not filled correctly, try replacing the cartridge and if that does not work, it could possibly be defective printer and you may have to recycle it.
Jan 09, 2015 | HP OfficeJet Office Equipment & Supplies
Hp officejet j5750
go to the HP website, pick products enter model number/tag and see if you can order new CD software or download an image on cd/dvd on another pc(if your pc is not working)
if this is a printer not a pc, do the same thing but download the software from the HP site to your pc to install it from online
not sure what hp officejet is
Nov 22, 2013 | Dell Computers & Internet
Delete fax received log
Hi there it will have what you need to know.
Click LINK= http://www.4all2sell.com/pdf/HP-Officejet-J5730-J5740-J5750-J5780-J5785-J5788-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
Mar 17, 2010 | HP Officejet J5780 All-In-One Printer
HP J5780 problem receiving fax-I can send faxes but not receive them. Phone is connected and works fine on incoming calls
Hi there
Mar 15, 2010 | HP Officejet J5780 All-In-One InkJet...
Paper jam
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Feb 25, 2010 | HP Officejet J5780 All-In-One Printer
Missing printed lines form HP Officejet J5750 All in One printer
Nov 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Oxd0620230 reset power
Below is the document that i want you to follow exactly in order to resolve you issue.
CLICK HERE ==>> DOCUMENT
Please let me know the outcome after following the steps.
thank you so much.
adonscott
Jul 17, 2008 | HP Officejet 5610 All-In-One InkJet...
I have apple ibookg4 trying to hook up hp officejet j5750 all in one
Not a very clear question. However, you need the software driver which you can find on the HP web site.
Assuming you have actually physically connected the two items together, download the driver and this will assist you to print.
Mar 08, 2008 | HP Officejet J5780 All-In-One InkJet...
202 people viewed this question
k24674
jasbo
jasbo
