Question about LG L1204R Air Conditioner
I have a new LG aircon wall unit and sometimes it sounds like its holding alot of water in the drain pan. I have it set up to what the manual said. but do not know if this sound is normal or not. So I was thinking about putting a drain hole in the bottom of it to help drain the water out better.
bobotfel
  • 236 Answers
SOURCE: LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Posted on Jan 14, 2008
  • 56 Answers
SOURCE: Loud sound when turning on LG aircondition unit
Is it the outside unit ofr the inside... either way sounds as if the blade is hitting the fan shroud. you should be able to access unit to see exactly where noise is coming from.
Posted on Feb 12, 2009
  • 53 Answers
SOURCE: my lg a.c. unit is spitting water from the front,
i have to, that problem many of time ,you are at a point to where you have to get the build up out of the system now because it wasnt draining, pour bleach in the system bottom base,an if you are firmiliar with drillin in some areas where it wouldnt harm any parts do so. it will help slow down the build up ,but do it towards the back of the unit,an also look for any additional drain plugs that could be undetected ,,hope i helped you out
Posted on May 16, 2010
  • 13 Answers
SOURCE: Installed an artcool in my appartment and it
first of all check the outdoor unit if it is in your reach  than simply touch both the valve & feel the temp if smaller valve is colder than the bigger one than surely the problem is with refrigerant quantity.
Posted on Jul 25, 2010
heatman101
  • 43501 Answers
SOURCE: Water collected in unit will not drain out of rear
Many newer units are made to retain the water a splash it onto the condenser coil...
you can drill a hole if the noise bothers you...
heatman101
Posted on Aug 19, 2010
Testimonial: "good knowledge, very helpful thank you"
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Loud noise coming from fan , alot of water coming inside instead of outside
The problem you're having is caused by the drip pan's drain being clogged near the rear of the unit and/or there is not enough downward tilt on the rear of the unit. 1/4" to 1/2 is the general rule of thumb for rear downward tilt. This allows the water to flow to the rear of the drain pan and out thru the drain hole. Instead of building up and overflowing the front of the drip pan. Be sure to turn the unit OFF & unplug it, before attempting to remedy the problem.
Correcting those to issues should solve the problem.
I hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | LG Heating & Cooling
How to empty water intake
If you have an LG Portable AC Unit,. The drain plug is on the rear of the unit, just above floor level. To drain it, use a low sided pan capable of holding 1 quart of of water. Unscrew the drain plug and drain it into the pan. OR disconnect the unit and roll it to a floor drain or outside and drain it there.
I hope I was able to help you and thanks for choosing FixYa.
Aug 18, 2011 | LG Heating & Cooling
Why does wall make ticking noise
Marvin, it could be water dripping into the drain pan under the unit or the metal of the outer shell is cooling off (metal stress). Also, is the drain pan is full the fan blades may be hitting the water, In which case the rear of the unit needs to be tilted down 1/4" to 1/2". So, the water will flow to the rear of the pan and out the drain hole.These sounds are normal and will do no harm. If you want to test this theory, turn the unit OFF & unplug it. If you still hear the ticking sound, it's one of the above.
Hope this helps & thanks for choosing FixYa.
Aug 11, 2011 | Frigidaire FAC124 wall/Window Air...
THE AIR CONDITIONER LEAKS WATER FROM THE FRONT OF THE UNIT.
Look for the drain line coming out of the unit typically in the bottom. Clear out this drain line with a vacuum or water hose. It should begin to drain and stop leaking.
If the leaking continues, you may have a cracked drain pan or severe drain blockage.
Jul 31, 2010 | LG Goldstar GWHD5000 wall/window Air...
Freezer door leaking alot of water on floor no ice on door
This really sounds like a plugged drain. When the unit goes into defrost the water should run down the drain into the drain pan...when the drain is plugged it will run over and down to the bottom of the freezer thus leaking out the bottom of the door and onto the floor. You will need to take everything out of the freezer and remove the screws that hold the back panel on break out the ice at the bottom and use hot water to pour down the drain to clear it.....also if you have a small hose to shove down the drain that will help out alot.
Oct 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects in the bottom of my LG LRTP1231W
Some units don't have a drain tube. The water flows down the back of the fridge into the bottom and it just makes a mess. It has been a problem ever since they started going "Energy efficient". The drain was a hole and they had to close the holes. If you're lucky enough to have the drain, it will be located inside the back wall of your freezer. The inside walls must be removed. The drain will be in the drip pan, below the freezing coils (fins) in the back of the freezer.
Sep 05, 2009 | LG LRTP1231W Top Freezer Refrigerator
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
LG LST243C-2
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
LG L1204R Air Conditioner Logo
69 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
