My Samsung htz310 home cinema kit keeps coming up 'Protect' and then turns off when i play CDS (both copied and normal), any ideas? cheers
  • bigpurns Jan 11, 2009
    My samsung htz310 keeps saying protect when im on my ps3. Ive got it hook up to the ps with an optical cable but just for the sound. I would be very greatful if someone could help as its a pain in the ***!!!!!!! many thanks.
  • klasern Apr 08, 2009
    Same thing, but i have noticed fluctuations in the sound to varies speakers lately. Sometimes the sound suddenly dissapeared from one speaker, the next minute, it's back. But now every time i turn it on, it says: "Protect" and turns off. I googled for answers, and got a tip about unplugging one speaker-wire at a time to see wich one that might cause the interference, but even as i unplugged ALL wires, it still read "Protect" and switched off. I fear i will have to send in for repears wich means a costly month without proper sound:(
Just kinda fixed one of these, well more of a bodge but it works !!
the protect error is to do with the main AMP board (the board the speakers connects too)
to FIX it, on the ribbon cut pins 4 and 5 which disables the checking ! It may due long term damage and break summit else, but hey its broke anyhows !!! even if its just to get the system running again to get settings off it !!!
Posted on Sep 08, 2009
"on the ribbon cut pins 4 and 5 which disables the checking"
where is this ribbon and pins located? thanks.
Posted on Jul 26, 2010
My samsung home cinema htz310 does not start it indicates PROTECT When power is switched off and disconected from ac for one day ,it will turn on and play normally Help please
There are a couple of possibilities for this problem. First that it is overheating. Check that it is well ventilated and not too enclosed. Don't leave papers on top of the device for example. Secondly you could have got a wringing problem, perhaps on the speakers. Shorts, bad connection or wrong type speakers even. Lastly a fault of some kind.
Jun 02, 2016 | Samsung Audio Players & Recorders
When I turn on the unit I get a symbol that is a circle with a diagonal line through it and then the unit turns off. Any ideas? (Samsung HT XQ100 Home Cinema)
Your fan is bad.
The system is intelligent. It knows it will overheat without a fan. It also knows there is a problem with the fan, so it throws its self into self-protect mode to keep from overheating.
Have a tech check your fan.
;o)
Nov 17, 2010 | Samsung HT-XQ100 Theater System
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Disc Unknown keeps coming up on the screen
check the dust content on in the m,achine then check your settings to make sure its adjust accordingly
Mar 30, 2009 | Samsung HT-DM550 System
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Mar 14, 2009 | Sony Televison & Video
Hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
Jan 20, 2009 | Samsung HT-Z310T Theater System
Wireless speakers
Google "Samsung SWA-4000" The HTz310 is wireless "ready" only. You'll need to purchase this unit for about $100 to make your (Rears only) wireless.
Dec 07, 2008 | Samsung HT-Z310T Theater System
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Getting audio from LG TV to play through Samsung Home Cinema System
May 20, 2008 | Audio Players & Recorders
Televison & Video Logo
1,243 people viewed this question
Top Televison & Video Experts
