Question about Dishwashers
I will turn on the dish washer and then it would stop i tried to find the filter on it but i do not know were it is
  • 901 Answers
Just follow the water inlet hose pipe till the machine body end. You will find a gland nut made of plastic material. Turn it anticlockwise by your hand. if it is very tight you can use a suitable tool.
after opening you will find the a small strainer ( filter ) fitted in the circular slot. Pull it by a plier. Clean it and re fix it. Do not forget to fix rubber ring. Check the water flow in the hose.
If you find water leaking, you have to replace the small rubber washer. Or use teflon tape and tighten.
Posted on Sep 15, 2010
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
What is e20 mean
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Dish washer not getting the plates clean.
WHAT KIND OF DETERGENT ARE YOU USING?
Jan 08, 2009 | Dishwashers
Kenmore 3.5 Quiet Tumble
Nov 03, 2008 | Kenmore 43142 Front Load Washer
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
White stains on dishes and clogging film in the sink. Plumber snaked sink and mentioned we need to change the filter in our kenmore elite dish washer.  Don't know where the filter is orb how to find it....
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Jan 02, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
