Question about Husqvarna Sewing Machines
How do you adjust the bobbin tension in the Huskystar C20 sewing machine, the manuel does not state this?
  • 260 Answers
There is a screw on the bobbin holder. Clockwise=tighten, counter-clockwise=loosen. Hope this helps!
Posted on Sep 15, 2010
How do I adjust the thread tension and bobbin tension on a Huskystar 207?
thread tension is by a knob on the face of the machine
if you find by adjusting that , nothing is happening , check the way the thread has been put in as it can get behind the pressure plates and jam on the bolt or not be between the pressure plates and just running free
bobbin tension is by the small screw that holds the flat spring under which you pull the thread after fitting in the bobbin back in the carrier
( seldom need to adjust bobbin thread tension)
Dec 13, 2016 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Need to know how to adjust tensions.
Make and model not stated. Most machines have a dial for upper thread tension. Higher the number, the tighter the tension.
Bobbin tensions can also be adjusted, but it is not recommend that sewing novices attempt to adjust bobbin tension. (Bobbin tensions are very sensitive and a slight quarter-turn will usually make a big impact. Plus, one should know how to return it to its original position if/when things go awry.)
Mar 31, 2015 | Sewing Machines
Huskystar 224 top tension will not adjust. Last time I used this machine was a week ago, everything was perfect. Yesterday I started a project, and from the get-go there were big loops on the bottom of...
Have you tried to re-thread the machine? Check to see if the thread is in the take-up lever. There also might be a piece of thread or lint caught between the top tension disks.
Feb 23, 2010 | Sewing Machines
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Mar 21, 2009 | Husqvarna Viking 1
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Sewing Machines Logo
189 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
