Question about Ricoh Aficio 1085 Laser Printer
Sc495 code - Ricoh Aficio 1085 Laser Printer
Normaly its the toner bank sensors if you have replaced thet check the waste toner clutch if you cant solve it that way vacuum all the toner pipes in some casses they are blocked
Posted on Oct 19, 2012
Ricoh aficio mp2105 error code sc495 how to recover
http://terraofficesolutions.com/forum/index.php?topic=36.0
Quoting from the link above:
Ricoh Error Code 495, SC495 Fix - Printer, Copier, Fax Machine « on: October 02, 2012, 11:18:43 pm » The Ricoh copier error code 495 / SC495 is a toner recycling unit error code.
If you receive this error you will want to check:
Your Waste toner transport is nor working ( motor overload )
Check Toner end sensor detective, (is not connected )
If the problem persists you may need to contact a local service technician to take a look at your copier.
Contact us by phone, email, or reply to this post with any questions you may have, we can always help.
Steve Jensen
steve@terraofficesolutions.com
(760) 580-4190
Mar 21, 2018 | Ricoh Office Equipment & Supplies
Why is it that am i getting a 585 and a 495 errors simultaneously on two of the same machines
You did not post the model number. I assume it is a larger machine such as a MP9000. The SC495 is a clogged toner hose from the cup to the toner sub-hopper. If the toner system is not clogged it is a bad toner pump, or sometimes it is a bad toner sensor on the sub-hopper or the cup on top of the auger from the toner bank. If the hose is not clogged and there is toner to the top of the sub-hopper then it is one of the sensors. They are identical.
Aug 11, 2014 | Ricoh Office Equipment & Supplies
Sc495
sc495 is a problem with the toner supply system. It may be as simple as a clump of toner clogging up one of the hoses, or it could be a bad toner end sensor or bad motor failing to transport the toner.
Aug 12, 2011 | IBM Infoprint 2085 All-In-One Laser...
I have a Gestetner DSm651sp and it is giving me an error code of sc495, I recently replaced the toner and its not detecting it. Please help!
Most likely the toner dispenser is blocked. Its not getting the ink into the system. Did you shake the bottle well to be sure its not packed inside the bottle?
Jun 03, 2011 | Gestetner DSM 651 Copier
What is a SC495 problem?
Hi
Clear or change the Tubes for Tonertransport, look for the Toner pump.
Often the Seal inside is broken, and u dont get enough toner, mostley
u can hear it, Look at the tonertransport from Tonerbank the coil must
bring enough toner to the collector from where its go to the devbox,
when u have problems with full tubes its better u give new one
because problems will come back to you
Pls vote us to keep us alive
Nov 16, 2010 | Ricoh Aficio 1085 Laser Printer
Sc 495
SC495 is generally a problem with the toner recycling system in a Lanier copier. Without knowing the specific model, I can't give you any more information. What model copier do you have?
Oct 06, 2010 | Lanier Office Equipment & Supplies
I have the same problem with a Ricoh aficio 700 SC495
check the door contacts and the contacts on the transfer unit these need to be clean also
Sep 17, 2009 | Savin 9935DP Laser Printer
Ricoh 2051SP error code J013 & SC495
SC495 is a toner recycling system error, due to strain on the system. Most likely due to a blockage. system needs to be removed and thoroughly cleaned. J013, is simply a jam, and this would be happening because of the toner recycling system being locked up, and seizing the motor. You DEFINITELY need a tech for this.
Jul 16, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1085 Laser Printer Logo
346 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
