Question about Timex 1440 Nylon watch
How do you set the watch? - Timex 1440 Nylon watch
  • 794 Answers
Hi jns75,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 15, 2011
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
How to set pocket watch
Hi John, There are several possiblitites depending on the watch you have. If it is a battery watch you set it like most modern watches by pulling the pendant and the hands should move. If it is a vintage watch it may set the same way. If gentle pulling the crown does not work try this. Your watch may be a lever set watch. This requires removing the crystal of your watch will be screwed on. If it doesn't loosen easily try putting the watch between your palms and twist. Once the crystal and bezel loosen remove it and set it aside. Now look near the 2 o'clock position. A lever set watch will have a small metal piece sticking up that is designed to be hooked with your fingernail and pulled out. When in the out position your watch will now be in the setting position and your hands will move when you rotate the crown. After setting push the lever back in and you will now be in the winding position. Replace the crystal and carefully screw it down but not too tightly. There are other systems but I am guessing this will cover your watch. Merry Christmas
Dec 18, 2011 | Orvis 82KG6000
How to set day on non digital george watch
I'm not familiar with the George watch but analog (non-digital) watches typically have a stem with which you set the time and the day. On most watches the stem has two clicks when you pull it out (gently). The first clich should set the day by rotating the stem counter-clockwise while the second click sets the time. On wind-up watches this stem also winds the watch when not pulled out.
May 01, 2011 | Watches
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Jul 04, 2010 | Watches
How the heck do you set this watch, ive tried for two days
Use this link: http://www.citizenwatch.com/COA/English/settings.asp Fill in requested details of your watch and click on GET SETTING INSTRUCTIONS, then click on INTERACTIVE SETTING INSTRUCTIONS. There you will find everything you need to set up your watch.
Rate me, plz.
Jan 06, 2010 | Citizen Blue Angels Skyhawk Watch
Setting time on watch
Here is a good link for setting the date.
http://www.fixya.com/support/p140271-citizen_nighthawk_bj7005_59e_wrist_watch/manual-1587/page-3
Hope this helps,
Ken
Yellowstone Watch Inc.
Sep 30, 2009 | Citizen Blue Angels Skyhawk Watch
Setting a Casio Wave Captor watch after battery change
If the watch is running try to sync the watch 1st, meaning set the minute and hour hands pointing to 12:00 o'clock. before you go to set the time.
May 22, 2009 | Casio WVQ600DCA Wave Ceptor Watch
Timex Watch
While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
Press the mode or bottom left button until the hour digits start to flash.
Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
Mar 09, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Timex 1440 Nylon watch Logo
19 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
