Question about Garden
Husqvarna 445 manual - Garden
  • 51 Answers
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
Hi i have a Husqvarna 445 18" 45.7cc the automatic
Verify you have oil in the oil fill tank. Try cleaning inside the drive sprocket cover. Release the chain tension and carefully dislodge the bar and chain assembly. Clean sawdust and debris from behind and inside the housing and behind the bar. Use a wisker wire to clean the through ports and channels on bar( these ports are the path that the oil travels to the drag groove that the drive links on the chain uses to pull the oil to the tip of the bar).
Please refer to this link below for your saw maintenance-
http://www.chainsawsdirect.com/manuals/HUSQ_445_MAN2.pdf
If this does not correct the problem contact Husqvarna customer service or a local service repair.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a interlude 445. do I need to take it in and have it oiled? Does it use up its oil over time and use?
No. That particular machine never needs oiling. That is one of the great things about a Husqvarna Vik sewing machine.
Feb 17, 2011 | Husqvarna Interlude 445 Sewing Machine
Model 445 chainsaw. Was cutting all day and no problem. Good gasoline, Husqvarna 2 cycle oil. All of a sudden started racing like the carb was stuck full open even when throttle trigger released. Then...
Engine speeding up on idle is normally due to an air leak, check the carb securing screws are tight, if you have a leaking crank seal it will be a shop repair.
Feb 28, 2010 | Husqvarna Forest & Garden #966906636 445...
I have a Husqvarna 445 chain saw and it does not get enough oil to the bar and chain. I have to stop saw after about 10 minutes of cutting because it freezes the chain so I remove bar and chain clean out...
Your Manual nor IPL mention an oiler adjustment..
445 IPL (may not be your saw)
Is this the original bar? A longer bar requires more oil and your saw is not equipped to supply it.
http://weborder.husqvarna.com/order_static/doc/USA/2007/I07000/I0701086.pdf
Detail B (Clutch/Drum/Oiler)
We are seeing many of these does not oil/oils to much problems with these no adjustment models. I recommend you contact Husqvarna, there may be an unannounced recall/repair. If they aren't willing to help you consider contacting your Atourney General and the BBB.
Contact Husqvarna here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
It has an outboard clutch, the oil pump is behind it. If you attempt a repair this will be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I’ve ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
Source for Manual and IPL:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Nov 24, 2009 | Husqvarna Chain Saw 20" Bar
Can't pinpoint bar oil adjustment on 08 445 husqvarna
There is no externally adjustable oiler on a 445. From your manual:
"If the chain lubrication system is still not working after
carrying out the above checks and associated measures
you should contact your servicing dealer."
HusqvarnaUSA.com
06 1500198
Oct 14, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Changing the chain on husqvarna 445
make sure the chain brake is off. Then undo the two retaining bolts and take the cover off.
Sep 19, 2009 | Husqvarna Forest & Garden #966906636 445...
Brand new husqvarna 445, won't start
Try not giving any throttle when first starting. The newer trimmers are this way many times. (Maybe the newer chainsaws are this way now.)You prime the carburetor, set the choke and pull, but don't throttle until it runs for 10 or 15 seconds.
Jim
Jun 03, 2009 | Husqvarna Garden
Garden Logo
690 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
