Question about Olympus EVOLT E-500 Digital Camera
Night shots using flash giving a bluish color effect.
I am not happy with the bluish effect everytime I take night shots and sometimes during day. Is there a solution to this problem?
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Try reset the camera back to camera defaults by putting dial on p, menu, custom reset
Posted on Aug 20, 2008
Try changing you're white balance [WB]
Light has different colours to it, depending on the source, which you need to compensate for.
Posted on Sep 21, 2008
Lorex night vision camera
Do you have a color night vision model camera? If not, then you will get color during the day and black and white at night.
Jul 10, 2016 | Televison & Video
All nite time pics are blacked out what can I do to fix it.
If the day time pictures are good then the setttings for the night shots must be selected according to the light intensity. Please check on the menu for night settings if you are intenting a low light shoot. Also make sure that the flash is active, in most of the present day samml cameras, the flash THROW is low and so the SUBJECT must not be too far as the picture will appear dark. So when using flash in a dark scene have the subject within 5-7 feet as the small flash will not be able to capture the openess. Also you can use a SLAVE flash to counter this and give a better prospective.
Sep 29, 2011 | Moultrie I-35 Digital Camera
When taking pictures at night, i find that its not that sharp and clear. that goes for the video shots as well. how do i rectify this problem. changing the modes doesn't very much. shots during the day is...
Night shots without flash will cause your camera to use a slower shutter speed. This can cause camera shake. To avoid this, put your camera on a tripod. Also, you can raise the ISO to a higher setting...however, too high and you'll get more digital noise in the picture.
Nov 04, 2010 | Cameras
My camera's (Kodak MD853) flash does not work. Everytime I try to use the flash a red light flashes a few times but the flash does not shoot.
evironmental settings for shutter speed and duration day or night or subject motion. maybe it is set for night in a dim but lighted place.
Aug 20, 2010 | Kodak EasyShare MD853 Digital Camera
Olympus mju850 - fine at night but hugely overexposed in daylight
it is ur luck if camera still works in indoor pics then only take indoor pics but the pics are not crisp and clear they need to be there will be dis colored and scratchy but u can try see which are better i think pics without flash with adequate light will be better one's
i am here to help u in this if u like
Apr 08, 2009 | Olympus mju 740 Digital Camera
Cencor propblem
I don't know the answer to this question, but all I do is disconnect my battery everytime I have issue with my Jimmy and it seems to fix the problem. I don't know if this is going to help you or not but give it shot. disconnect your battery for 5 minutes and see what it will do.
Mar 18, 2009 | 1999 GMC Jimmy
How do i get good pictures when taking it during the night and able to focus the camera to get the real nature color of the drak
You'll have to use a tripod to get good shots at night, because in order to get a lot of colors in your photo, you will have to set it for long exposure times. Good luck, and have fun!
Aug 16, 2008 | Nikon Cameras
Itt night quest 150
Not sure if this applies, but this is on the Morovision site: http://www.morovision.com/faqs.htm Because of the manufacturing processes, all night vision image tubes will have different cosmetics such as small spots or specs, photocathode coloring, or a chicken wire effect from the microchannel plate. Most cosmetics are only noticed during viewing in high light situations such as viewing with the daylight filter on in a lit room. Most cosmetic blemishes are not noticeable during normal nighttime operation but may still be seen to some degree in certain situations. These cosmetics in no way effect the performance of the image tube and do not decrease the ability to perform nighttime tasks.
Jul 11, 2008 | ITT Night Mariner 160 Monocular
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Out of focus shots at night
First, check to see if you're in auto or program mode, as opposed to manual or possibly even aperture priority (if it supports it). Typically, auto or program mode sets your shutter speed to around 1/60th of a second, which is usually good enough to hand-hold a flash shot without blur. The camera should emit enough flash - within its range, of course - to get a good exposure. You typically won't get a good flash shot if your subject is more than 10-12 feet away. If you want, you should be able to go back and look at the way your camera was set for each shot with a program like Photoshop or Elements. That information is stored as "EXIF" data, and if you select a file in Photoshop CS' file manager for example, you should be able to see what the shutter speed was on any given shot. Let's suppose you look at some old, blurry night-shots - the EXIF data, that is - that should've turned out OK and your shutter speed and everything look fine. At that point, I'd try taking some flash photographs using a tripod at night which would eliminate camera-shake as a possible cause of the blurry shots. I suspect that the likely cause was your camera wasn't in the correct mode though and once you get that squared away, it'll be OK. Good luck!
Sep 13, 2005 | Olympus Camedia C-770 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
77 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
