Question about Whalen FirePole 41420 (28 inch) Patio Heater
Whalen Firpole Lights and fills burner with flames and then shuts off after a few seconds.
    Scholar:
  • 41 Answers
I am assuming it is a Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Hope this helps. Regards Bryan
Posted on May 27, 2008
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
Tip
Gas Furnace Lights for 5 seconds and shuts off - it will do this 3 times
If the burners of your furnace light and go out after approximately 5 seconds, the problem is most likely with the Flame Sensor. The Flame Sensor will develop a light coating that will prevent it from sending a "proof" signal back to the main board. If the main board does not receive this "proof" signal, it will shut off the gas valve. After 3 attempts, it will lock out leaving only the draft inducer motor running. Here is a video demonstrating how to identify and clean the flame sensor to get your furnace back to running normally in only a few minutes.
on Mar 20, 2010 | Heating & Cooling
My adp cuhn-60a-2 sparks an lights burner ok, burns for only few seconds an shuts down burner, repeats this three times an whole unit shuts down?
You are describing the typical issue for a problem in the 'flame rectification' circuit. Turn the powere off. Find the flame sensor, it will be on the opposite side of the furnace from the spark ignition device. Carefully remove the sensor and clean with fine sandpaper, then clean the wire connector on the end of it if so equipped, then follow that wire all the way to the circuit board, remove the wire connection and clean it and reinstall. Many times that solves the issue.
Some systems utilize the spark ignition electrode as its own flame sensor. IF there is no separate flame sensor, perform the above task on the ignition device instead. Be careful NOT to bend the probe, crack the ceramic insulator or reinstall it malaligned. Its location in the pilot flame is critical. Slight relocation by improper handling will render it unable to ignite the pilot gas.
There may be another issue as there are many things that cause ignition lockout, but this is the first thing to do to eliminate the situation you've described.
If you are unsure of performing this and ANY minor maintenance to a gas fired appliance, abandon the idea and call a qualified service tech to proceed.
Dec 29, 2014 | Heating & Cooling
Burner shuts down after it lights
Is the unit newer, and if so do the flames light for a couple seconds and go out a few times? If so this would most likely be a flame sensing problem!
Apr 15, 2013 | Heating & Cooling
I have a Johnson air ease 90 plus.I turn the thermostat up and exhaust blower comes on igniter comes on and i can hear the natural gas release for a second or two then igniter shuts off along with gas. Fan...
If the burners come on for a few seconds and shut off check the flame sensor near the burners and clean it with steel wool, usually this will fix the problem. The flame sensor is a metal rod that is immersed in the burner flame on the opposite side of the igniter. robhvac47_7.jpg
Jan 17, 2011 | Heating & Cooling
C4 error 12, cleaned the burner assy, filled the p...
I have the same problem since i bought this stupid water heater, it sucks. I had there service men come out and all they did was clean the burner sensor. Few months later i had the same problem. Then I called customer service and they tried saying that it was the exhaust what was causing the problem. What i found out is that the flame SENSOR and not the BURNER is the problem. Remove the burner and clean/scratch of particles of the tip of the flame sensor, it may look like its clean but you just have to scratch the head off clean with a small metal brush. Then reinstall the burner back and you will be fine, but just for a few months. Then you will have to do the same all over again. Hope this will solve your problem temporally.
May 20, 2010 | Rheem Paloma Tankless Water Heaters...
On my goodman gmv95 blower starts, glowplug lights, gas turns on, then glowplug goes out and gas shuts off. any suggestions what the problem could be?
You did not mention how long the main burner stayed on. If it stayed on only a few seconds, most likely you have a dirty or bad flame rod. The flame rod is located in the flame path of the last burner to ignite. Take a toothbrush and scrub off any debris that may be on it. Also check all the wire connections from the rod back to the circuit board.
Feb 13, 2010 | Goodman Heating & Cooling
Goodman furnace seems to be cycling too often. Burner not staying on long enough to put warm air into system. Burner quits after a few seconds then repeats.
dIf the burners are only staying on for about 5 seconds, you proably hav e a dirty flame sensor. Watch the burners light, the glow plug will light one end of the burners, in front of the last burner to light the will be a small thin rod, this rod must sense the flame or the gas will be shut down. Take a piece of steel wool and gently cleqan the rod.
Oct 11, 2009 | Goodman GDS80904BNA Open Flame Heater
Dometic refrigerator in gas mode burner comes on than shuts off
if you have spark ignition it is possibe you have a bad flame sensor
Apr 10, 2009 | Refrigerators
DOESN'T FIRE - 1 BLINK CODE
if the unit fires-up but drops out soon after then you main burner flame sensor is not working
Nov 25, 2008 | Goodman GDS80904BNA Open Flame Heater
Whalen FirePole 41420 (28 inch) Patio Heater Logo
105 people viewed this question
Top Whalen Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Whalen Heating and Cooling Expert? Answer questions, earn points and help others
