Question about Compaq Presario 5000 PC Desktop
Acrord32 error Unable to open pdf file. Always showing acrord32 error. Already have Adobe reader 8 .
  • 67 Answers
Try to uninstall Adobe and install it again. It helped me.
Posted on May 16, 2008
Font Capture AcroRd32.exe - Bad Image error
C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\AcroRd32.exe
That one? or another version?
Nov 24, 2013 | Computers & Internet
Trouble Opening PDF files in Firefox 8
Could be you need the latest Adobe pdf file reader on your computer to open the files. Software can be such a PIA. Can also be because you are using firefox 8, a real old version of the browser. Update the browser!
Jun 12, 2017 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
I can't open pdf files. As AcroRd32.exe-- entry point not found
try install acrobat reader
you can download hare
Feb 18, 2011 | Computers & Internet
I cannot open files on my computer that require them to be open by adobe which I have on both my laptops. The files save then you have to open them with a program but it trys to open with word which does...
I assume that you mean Adobe Acrobat reader. First of all make sure that you already have installed this program. Go at start - programs - and browse all programs to locate that Adobe Acrobat Reader existing. A good idea is to open it in order to check that it's fully working. In case of a problem download it from this official link. Since you are sure for the Acrobat Reader's existence, right click at any pdf file (these type of files open with Acrobat Reader) - choose open with - go at the bottom of the new window "choose program" - at the new window select Adobe Acrobat Reader (in case it is not available click on browse and navigate at the C:\Program Files\Adobe\Reader x.x\Reader, select the file AcroRd32, hit open - check the box for "open this kind of files always with the same program" - hit OK and you are ready. From now on every time you will double click at a pdf file the Acrobat Reader will open this file.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
Feb 05, 2011 | Adobe Computers & Internet
Cant open pdf
Make sure only adobe 9 is the only version of adobe reader you have installed on that computer. Then go to where your PDF file is and right click on it with the mouse and go into properties.
In the general tab where it says type of file it will show you what program is opening up the PDF file. Click on the change button and where it says recommended programs see if Adobe reader is there, if its not then down below where it says other programs click on the down arrow and see if adobe reader shows up there. If it shows up in either section then choose it, then click on apply, and then click on okay.
Now if for some reason adobe reader doesn't show up in either section, then you'll need to browse for it. It normally installs itself in the program files folder, then double-click on it and go into the adobe folder, Adobe 9.0 and then the reader folder. The name of the reader program looks something like acrord32 and it will say application to the right of it. At that point choose it and apply the changes so it opens up with Adobe reader.
This should cover everything, if your still having problems, let me know and I'll help you out further.
May 22, 2010 | Dell Dimension 4600 PC Desktop
There was error in opening the document, the file has damaged and could not be repaired... This error i got while opening my pdf document, can you please help me in resolving it as that document is very...
uninstall Adobe Reader and reinstall it or download it from
also checked for the default file extension ...
change .PDF to open with ADOBE reader always ..
after u install the adobe reader and complete teh setup
rt click on the file that you want to open click on open with
select ADOBE reader as default format ..apply.... ok...this will work
Mar 19, 2010 | ScanSoft PDF Converter Professional...
Same issue: Unable 2 download/view pdf files online.
In Inernet Explorer window, click Tools menu, find Manage Add-Ons.In the window that open look for a drop-down list, select all add-ons and see if Adobe Browser helper Object add-on is enabled. Enable it if it is not. If that does not work reinstall Adobe Reader.
Hope it helps
Sep 07, 2009 | Adobe Acrobat 6.0 for PC
Adobe Reader version 8
Try this fix,
1.dowload windows installer cleanup utility from the following link.
Under more information, tab
2. Install and run the same from Start> All programs>windows installer cleanup utility.
3. In the box keep on selecting all items that say adobe and click remove. If you have multiple enteries might need to select them one by one.
4. Click on Start >My computer>Local Disk C:>Program files and delete the adobe folder
5. Restart your computer and again download and install adobe reader , it should work fine .
In case it still does not work and you need to open pdf files download
foxit reader from the following link
Jun 07, 2008 | Adobe Acrobat 7.0 for PC
How to open PDF files with Adobe
Witch version your install first tell me I think your install acrobat 5.0 (simple) Click Start go to run type AcroRd32 press enter then open pdf supported software open next go to file menu click open wear your files is their then open ok support see this web
Mar 12, 2008 | Adobe Acrobat 7.0 for PC
Compaq Presario 5000 PC Desktop Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
