Question about HP LaserJet 2420dn Printer
I Have a HP 2402d and when i start it up the memory counts to 128mb on the lcd display and then the printer does nothing else
    Genius:
  • 1,089 Answers
Power the printer off and pull the plug.On the right side of the printer is an access panel, slide it back to disengage it. Now you should be looking at a metal cover. Pull it out from the front to open it and lift it off its hinges. There will be at least one memory DIMM facing you. If there are two, remove the lower one. Power the printer up. If it initializes, good. That means that the DIMM you pulled is bad. If it still fails, power down, pull the plug and remove the other DIMM. Power up. If it works the 2nd DIMM is bad. Power down again and put the 1st DIMM you removed in the slot that the 2nd one came out of. power up and order another DIMM. Don't forget about the covers!
Posted on Sep 15, 2010
Cold reset hp p4515
Power off the printer, power the printer on and when the memory count starts in the display, press and hold the checkmark button until all three lights on front stay on. Release the checkmark and use the up arrow until display reads "cold reset" and then press checkmark again and printer will restart.
Apr 15, 2014 | HP P4515n LaserJet Printer
How can tell if the ink level is low? hp 2420
Cartridge comes along with memory, the information of estimated ink/toner levels will stored in this memory(Depends upon the cartridge model yield will varies). When printer performs the printing, memory count will comes down, when its reaches the minimum count printer will display the message of "low ink/toner/remain pages" levels, once its reaches to '0', display will changes like "replace the cartridge"...But there is no electronic component or mechanism to measure the ink/toner levels in the cartridges.Only estimated levels only printer can recognizes.. Take usage page through menu, you will get the information that usage % & printed pages info,you can judge how much remain it can print...
Dec 06, 2011 | HP LaserJet 2420 Printer
HP LaserJet Color Laser Printer 4650dn printer displays 49.5001 Error
Try this....power cycle the printer. When the memory count starts Press and hold the MENU button.
Release the MENU button when all 3 LEDS are lit.
Press the < button
The display will show INITIALIZE DISKS if you did the above correctly.
Press the green CHECK button and wait for the printer to come READY.
Sep 08, 2010 | HP LaserJet 4650 Color Printer Manual...
Hp desktjet printer won't work after installing refilled cartraige hp 4200
follow any of these to reset it and will work
http://tricks-collections.com/reset-hp-laserjet-4100mfp-4101mfp-4200-4300-4250-4350-9000/
or
1. Turn the product off.
2. Turn the product on.
3. Press and hold down the checkmark (Select) button while the memory is counting. The memory starts counting at 000MB immediately after you turn the power on.
4. Continue to hold down the checkmark (Select) button until all three LEDs are illuminated.
5. Release the checkmark (Select) button.
6. Press the up arrow (Navigation) button until the message New Maintenance Kit appears on the control panel display.
7. Press the checkmark button once.
the check mark is the v like sign ..
Sep 02, 2010 | HP Office Equipment & Supplies
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
HP LaserJet 3055. All of a sudden it stopped working. after powering up, it does "nothing" HP appears in the menu window, but that's it. none of the keys works, no way to even test it. All cables are...
Perform a cold reset
  1. Turn the printer on.
  2. Watch the control panel.
  3. When the memory starts counting, press and hold the green c00007906.gif (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
  4. Release the c00007906.gif (Select) button.
  5. The control panel will display SELECT LANGUAGE .
  6. Press c00235041.gif (Down Arrow) button until control panel displays COLD RESET .
  7. Press c00007906.gif (Select). The printer will perform a cold reset and then continue its power-on sequence.
Dec 14, 2009 | HP LaserJet 3055 All-In-One Printer
HP 4650 turns on, does the count up to 128MB, HP logo appears then it stops and only "initializing" on display.
Remove the Jetdirect card and try it. These tend to cause this fault. If not, possibly down to the formatter board
Oct 12, 2009 | HP LaserJet 4650 Color Printer
HP 4650 stops at "initializing"
REMOVE THE BATEERY IN THE CARD AND DO COLD RESET
Apr 20, 2009 | HP LaserJet 4650 Color Printer
First time using my hp color laserjet 5550
We need to start with turning the machine on not connected to the computer.
Disconnect machine from computer.
turn machine on
if locks on memory count 128mb turn off.
If machine has a jetdirect card (network card I/O) installed remove it.
Turn machine on.
If it comes READY you found the problem.
If you are not using on network reconnect to computer and try again.
If there is no network card let me know.
hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP LaserJet 2420dn Printer Logo
76 people viewed this question
Seeker5211
Seeker5211
