Question about Gateway Computers & Internet
Hello, I have a network adapter problem i suppose. I cannot connect wirelessly , i have other laptop they work! It says problem with your router or modem, which i don't think so at all! it is a new laptop still under warranty, but i am having problems with their IT after 4 emails back and forth may be they will accept to send it ! but i still want to see if i can fix it myself.
    Brigadier General:
  • 4,044 Answers
Make sure the wireless card is actually connected, turned on, and you are using a router that transmits to correct signal. If your router uses Type N and your computer uses G, they will not talk to each other. Make sure you have the correct settings in the computer are correct for your network and you have the correct security key set in the computer if your using WEP or WPA security on your network. If all else fails, you can try uninstalling the wireless adapter through Device manager and rebooting and letting it re-install.
Posted on Sep 15, 2010
I have a dynex enhanced wireless g network adapter. The computer that uses it is a windows xp. The computer will recognize it and it will show up but I can't connect it to any wireless networks. There is a...
Does the stick see any other wireless networks? Can you try creating an Ad-Hoc network from your other laptop to this one through the USB stick? If the answer to either of these two questions then the stick is working fine.
I would check to make sure your router is not using solely a N network type because the USB stick will not support it.
If you are using a duel band router and you are currently using the 5ghz network then the USB stick will not detect this either.
Lastly if your network is not being broadcast, your laptop may connect to the network but your USB stick will not be able to locate the network.
You can also try power cycling the router (unplug for 30 seconds) and then search for networks again.
Thanks,
Pat
Nov 07, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
Laptop does not receive any signal from router.
You have not mentione the issue. You have just posted that everything is allright and working.
Sep 01, 2009 | NetGear WGR614 54Mbps Wireless Router...
Can i use Bluetooth USB Adapter to connect PC to wireless router?
No, I am afraid not. the bluetooth adapter will not connect to your wireless router because as of now there is no router that support that function.
you can buy a USB wireless adapter instead.
thank you for using Fixya
Aug 03, 2009 | Linksys (USBBT100-CA) Bluetooth Wireless...
Wireless laptop finds signal, connects to network but no internet
just a thought but may be you can try to remove the WEP/WPA and select the connection mode based on MAC id, hope it was some help
Jul 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
I can not get my wireless adapter to work on my laptop
First you need to connect the wireless router to your desktop computer through an RJ45 Cable and setup a new wireless network. to do this you go to control panal you'll find (Wireless Network Setup icon) click on it and go through the process, when you get to "network key" select automatically assign a network key then select setup my network manually and next, then finish. once you do that, now you have a wireless network. connect the wireless usb dongle to the laptop and download necessary drivers for it once it shows on the little icons on the bottom right of the screen right click on it and it should have an option to enable the it. if not, then the dongle has the wrong driver installed or its faulty. once its enabled, go to my network places and choose wireless network and click search for wireless networks, you should find your Router's network, select it and click connect and that should be all.
let me know if you need more help and try to give me error messages and steps you did before, so i can help you. good luck !!!
Dec 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Cannot connected wireless
have you checked if the wireless adapter of your laptop is on?
if its already on.
on the system tray r'click the icon for wireless connection or double click it, check if your laptop can detect the wireless network, if you can detect it, highlight the wireless network and click on connect.
make sure that you know what is the wireless settings of your router.
check this link http://www.dlink.com.ph/products/dlhome.asp?sec=&pid=602 to get information how to change the settings on your wireless router if needed.
have a great day ahead.
Oct 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Computers & Internet Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
