Question about ASUS A6U Notebook
Asus a6000 start 3 seconds stop,sometimes disconnect ac and will start then can plug ac back and ok till next start
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 18, 2010
Testimonial: "Thanks tried above and power supply ok but even with battery removed takes 30 to 40 attempts to start,when it does you can hear the sound of relays "
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
How do I fix ASUS 1225/R252 Series, specifically the ASUS 1225B netbook WILL NOT POWER ON?
Is the machine processor way clean dustfree, is the bootable block of the drive damaged ? or ..... ?
If you are have do all the things read here on bleeping computer first how to take the right way , because of the different options by these kind of problems.
get always a life linux cd or a redo cd to get your maps with programs and maps to get it of it or to copy it to an other computer
THERE ARE MANY PROGRAMS BUT BE CAREFUL WITH IT.
http://www.bleepingcomputer.com/download/combofix
Dec 23, 2015 | ASUS Eee PC 1225B AMD E-450 1.65GHz...
Battery are charged but won't turn on and it in lock mode
Regarding your question you could try a power discharge for your device:
- disconnect the AC adapter
- unplug the battery (if detachable)
- press and hold down the power button for 30 seconds (to discharge the components)
- plug the AC adapter only (without the battery if it is detachable)
- turn on the unit
If the battery is not detachable, please follow the procedure with the battery attatched.
- turn off the unit
- turn on the unit
Click on the link for the user manual for your device:
http://dlcdnet.asus.com/pub/ASUS/EeePC/1225B/E7100_ASUS_1225-R252_Series_eManual.zip
Dec 23, 2015 | Computers & Internet
Laptop asus K70 only green lights and sound of harddisc and fan
Do you get bios beeps when you remove the memory all together? If no, then I would suspect processor or motherboard failure.
Feb 13, 2015 | ASUS Computers & Internet
Please help. i'm stock on the asus logo.
Take out the battery. Do not plug in the ac adapter. Hold down the start button for 5 seconds. Put battery back in. Plug in ac adapter and try to start the laptop. This might clear bad data in the bios,
Jan 23, 2014 | ASUS A8F Notebook
My asus ul 30jt won't start up. Fan starts lamps flickers and then stop for some seconds and then the same again. Tried to plug off everything and hold powerbutton for 45 sec and the plug in everythng...
Hey looks like you might have a clogged venting port for your processor, or a bad driver for your video card. To fix the clogged port, disconnect the power and battery, get a vacuum with a plastic end and place it at the entrance of the port and if possible move it back and forth till you see the clog disappear or hear a small release. If its the driver then do the same by powering down and removing the battery. Using just the power cord reboot the computer with the original system operating disk in the dvd drive and either choose repair boot and or system. Good luck that should take care of it.
Jul 03, 2011 | ASUS UL30A-X5K Notebook
ASUS a6000 km boot problems
check your ram, hard disk and operating system
Aug 22, 2009 | Computers & Internet
LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Apr 05, 2009 | ASUS MM17T (Silver) 17 inch LCD Monitor
Flashed the bios with wrong version PC is unusable
Hi, I dont like your chances a lot. Next to the cmos battery you will find a set of jumper pins [3 pins] move the jumper from where it is set onto the next pin and leave it there for at least 10 seconds then replace it back in its orriginal position. This will reset all the orriginal bios settings. If the update flash you have done doe's not allow this to reset, get onto the ASUS web site and ask for tech help, the response may be slow but this is your only option other than another mobo. Regards mistyman
Aug 27, 2007 | ASUS Intel 440BX Chipset P2B-N Motherboard
ASUS A6U Notebook Logo
542 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
