Question about Brother MFC 210C All-In-One InkJet Printer
Change carthage on printer
Help
    Problem Solver:
  • 7 Answers
What do u need help with ?
Posted on May 16, 2008
I have a kodak printer esp5250 i have cleened the printer head and changed the printer head still the black ink still not comming though can some one help me thanks ian
If you changed the head not much else to do but change out control board. Did you check your software to make sure its not like I do sometimes telling it to only print in blue. You may need a new printer. Reinstall the software before you do anything else. Windows does have a problem of losing printer data. Cant explain but tech guy has told me numerous cases of it.
Jan 29, 2015 | Kodak ESP5250 All-In-One InkJet Printer
How to change from serial communication to parllel com mode
OS settings to change port ---------------------------------------Click Settings > Control Panel > Printers and Faxes > Select your installed printer and right click on it > select properties > Ports > change serial port to parallel (COMx to LPTx)
Printer Settings to change port-------------------------------------------------Click here for EPSON user manual and refer page number 36 for printer settings. Change I/F mode to parallel (Interface mode) as instructed by Epson.
Feb 17, 2012 | Epson LX-300 Matrix Printer
Vertical line down scanned document
Hello
Try cleaning the scanner window and change the cartridge of the printer and see if it helps. If it's a laser printer then changing the toner should help ,also change the image drum if you have a laser printer.
Good Luck
Feb 09, 2012 | Office Equipment & Supplies
Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Jan 09, 2012 | HP Photosmart C3180 All-In-One InkJet...
I replace my Black ink with new and it will print only a few times then the black streaks and then stops working. I clean the heads and it don,t help. Change to another new black ...same thing print a few...
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 04, 2010 | Kodak 5300 All-in-One InkJet Printer
ABOUT 3/8 OF IN INCH IS NOT PRINTING IN CENTER OF ROW.I CHANGED PAPER BUT SAME THING. IS THERE ANY WAY TO CLEAN HEAD?
Hi dont worry
remove the Carthage (Toner )
check the dram there might be a dust on it you have to clean it with Cotton
(don't use water or spirit)
Jan 03, 2010 | Epson C31C412144 Thermal Printer
My printer says it's off line and won't print. I'm not sure what setting got changed or how to change it back. how can I change it so it prints again? help please!
1. Open Start menu.
2. Click on "Printers and Faxes"
3. Double-click the icon for your printer.
4. On the menu bar, click "Printer" to open the printer menu. Click on "Use Printer Offline" to remove the check mark. This will bring your printer back online.
If this did not help, check the printer itself & make sure it is not set to be offline.
Nov 06, 2009 | Xerox Phaser 8400 Laser Printer
My printer alarm after i changed cartridge
you may have touch/damage the sensor when you force the head... try to reinitialize your printer and reinstall the cartridge
Aug 29, 2007 | Canon BJC 4300 InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
