Question about Philips MC-230 CD Shelf System
Moved house and cannot get tuner to work..old lady here. There are red and black wires on both speakers at the back tied in neat bundle but not going anywhere. Search does not bring up any station...volume is turned up..power is on...don't know what to do. Shelf sytem Philips MC 230/230
  • ktroup Sep 15, 2010
    Thank you for your detailed help. The red and black wires are attached to the unit from both speakers.
    I cannot find any grey and white wires anywhere..they must have got lost in the move. I will keep searching boxes and hope I can get back to you tomorrow. Also I notice there appears to be a round 'power plug" hole at the bottom of the rear of the unit..what is this and what sort of cable am I to look for. Does it have an adaptor..box thing. The CD plays fine..so the speakers must work. There is no hum or static when radio is on. I appreciate your help.
    President:
  • 4,070 Answers
Hi! May you please move the unit on a different location? The signal may be poor that's why the tuner can't get any of the stations.
Posted on Sep 15, 2010
    Guru:
  • 374 Answers
Ok, you have to look in the back to be sure that each of the speakers are hooked into the unit itself. If you take a look there should be a little inlet(kinda like clamps or something that locks down on the wires.)
After yuo examine the wires from the speakers there is also wires for the radio. They should be located on the stero unit itself and the wires should be a gray/black(can be differant depending on what they sold with that particular item.
There shgould be a "radio" outlet simular to the ones used for the speakers. plug these in(clamps or one you possible roll) and more the wires seperate each other.
Let me know about the sound first. Is there any noise coming from the speakers??(a hum or static)
  • Robert Dahmen
    Robert Dahmen Sep 15, 2010
    Hello again
    We will need to get you the other wires to get them plugged in. The other wires were for picking up reception for the radio. These can be picked up for a few dollars at a electronics shop. I can point some out on the net if you would like.
    as for the the power plug at the bottem. Is there are more you could say about it in terms of reception???
How do I connect an old 3-way toggle switch to my new 3-way dimmer?
Cookrobert- you have to determine wich wire is the common wire in the box (house). Look in the box and see wich two wires ore in the same sleave. (These will be your travelers, (more than likely a black and a red) the wire that is in its own sleave (black)with a white tied to other whites is the common. Now the dimmer will tell you wich wire is commom. Tie the tow commons together. The green wire is ground if your house does not have ground , cap it and forget the green, if your house does have a ground (bare copper wire) then connect the green to the bare wires is the house box. Now your to travelers on the house side will tie to the two travelers on the dimmer side. Once you have found the traveller's on the house side and dimmer travelers they can be flip flopped. It dosnt matter. Just as long as they are the traveller's it will work. It sounds complicated but I'm sure you got this. I'm a 30 year electrician. (master).. I'll be looking for your update my friend. Good luck
Jan 21, 2015 | Electrical Supplies
Iam replacng my home a/c blower motor. My unit hasa red a black and a white wire. My new motor has a black wire a blue wire a red wire and a yellow wire. I need to know which color wire goes to which
On the original motor, red was low speed, black was high speed and white was common. The new motor should either have a diagram on the side of it or within the box for verification, but the black SHOULD also be high speed and the red wire SHOULD be low speed , the blue wire SHOULD be medium and the yellow SHOULD be common. However, you MUST verify those connections on the wiring diagram provided with the new motor before you connect or you will probably let out the MAJIC SMOKE !!! The speed you decide not to utilize can just be taped off and zip tied to the bundle.
You made no comment about two brown wires, and if either motor has two browns, they go to the run capacitor.
Dec 23, 2014 | GE Heating & Cooling
Jayco Battery Wiring issue
Well black is usually ground or negative. The chassis provides a common ground so it could have been attached to the frame.
Jul 03, 2013 | Cars & Trucks
I have a DC Z-92 amplifier,PD-Z82M CD player,PLZ-92 Phono deckand F-Z92l tuner, was working fine till moved house,lost manual on how to connect it back up again,can hear very faint sound from speakers but...
first make sure you have phonograph and everything else plugged in where it belongs. or better yet unplug everything and start over. plug in just one source or just use the tuner. make sure that the speaker wires are not shorting out on the back of the amp or at the speakers. if there is a speaker switch on the front (for speaker A or Speaker B) make sure speaker A is pressed in (if you hooked up Speaker A on the back (you may not necessarily have speaker switchs.) make sure when you try the tuner that it is tuned to a good solid station. If after all of the above it still doesn't work, maybe the move caused somthing to come loose inside
Mar 20, 2011 | Pioneer Audio Players & Recorders
Purchased utilitech 0192773 self adjusting wall timer. planning on installing in garage wall switch box for outside lamp posts, 3 total. the wiring in switch box consists of grounds tied together, 2 whites...
you got the wires you need. add switch's white to the white bundle in the back; green to grounds, red to the black going to the light; black to the other black. worked for me!
Jan 29, 2011 | Computers & Internet
Which speaker wires feed which speakers throughout my house?
Since this is a custom install and the wires don't follow a rule the only way to find which is which is to disconnect all the remaining speakers, plug in light bulbs in their places and check every single pair till they all match and their corresponding bulb lights up.
Dec 06, 2009 | Audio Players & Recorders
Our Phone wiring is underground and the connector box on the outside of mthe house was done in1978. My problem is that I hit the wires and some of them were knocked loose from the terminal and now I don't...
green wires and red wires.......... that is line one. also solid blue and blue with a white stripe is also line one..... so tie the greens and blue w/white stripes together and tape off (if not screwed down to block), and do the same with the red wires tied together with the solid blues.
yellow and black is line two.....and so is solid orange and orange w/white stripe. then just fill in the blanks as stated above.
its simple, think of the wires as speaker wire in a way to simplify what you are looking at. multiple Pairs (+/-) wires color coded. if the wires came off of the screw down posts, just match up the colors like stated above on the posts and screw them back down.
Nov 13, 2009 | Uniden 5.8GHz 2Handset Digital FHSS...
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Pioneer deh-p520 super tuner 3
Black, red, gray and white (for the front speakers only).
Black: Ground
Red: VCC
Gray: Speaker
White: Speaker.
Remember to isolate any unused cable like the blue (remote), green and purple (rear speaker).
Feb 15, 2008 | Pioneer DEH-P5200 CD Player
Philips MC-230 CD Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
