Question about Bosch Dishwashers
My dishwasher starts but the main pump does not go just put in new pump
  • 901 Answers
Check whether the pump power is getting ON. If not check the wires and the relay attached to it.
Posted on Sep 15, 2010
Machine starts fills Ok but when it clicks on to start the wash pump, nothing happens, I can hear a faint hum. When cancelling wash and starting new wash it pumps out ok too. After rinse cycle it indicates...
sounds like your main circulation pump is not working, if it is humming when it is supposed to start, sounds like it is getiing power, so probably not the control circuits, can you measure voltage to pump?
if you are getting 120 there, probably pump motor is dead
Mar 02, 2013 | Asko D1876 Dishwasher
Fisher and Paykel Nautilus Dishwasher wont advance to take water in .
The problem could be with flood switch at base of dishwasher. Press the float to check if it springs back. Otherwise switch under it is faulty.
Jan 19, 2013 | Fisher and Paykel Dishwashers
My dishwasher takes water but does not start to wash it pumps the water out and takes new water and that's going forever
SOUNDS LIKE THOSE LITTLE ROACHES GOT INTO THE CIRCUIT BOARD AND FRIED IT.
MAIN CIRCUIT BOARD HAS BEEN SHORTED OUT
Apr 30, 2012 | NEFF S54T09X1GB Fully-Intergrated Full...
The dishwasher makes a whining noise while washing; It started doing this a short time age. The dishwasher is about 1 1/2 years old. It almost sounds like there is something in the pump, , but I can't find...
The problem would be either something in sump area of the pump near the chopper or a bad main bearing in the motor. Since it is fairly new I would suspect something in the sump. I have put together some instructions on how to take this apart and clean. Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 05, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Won't start cycle???
check the main power make sure it is ok.
the door lock and or the control board can alos be faulty
Apr 09, 2010 | Dishwashers
I am installing a new pump on my asko dishwasher pump but not sure which wire goes where
there should only be two or three wires main wires brown & blue or red & black. green or green with yellow stripes is earth wire main wires connect to pump motor earth connects to earth point hope this helps
Nov 14, 2009 | Asko 1385 Dishwasher
Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher trips the house mains
try to diconnect the heater and run the unit.
Oct 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Jul 19, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
