Question about SanDisk Sansa e250 MP3 Player
I cant delete videos from my 4 gb sansa
i cant delete videos and i cant reformat program too.
when i click reformat , its says:
what i have to do?
help me plz
Change it to fat32 and format it. it should work
Posted on May 16, 2008
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
Can't find clip in my computer
This is and excerpt from "EphMusicFan" on the Real player forum. Original link is also below.
" The following steps finally fixed everything for me. While it may seem long, it only takes about 15 minutes and should fix everything.
If you run windows XP don't have Windows Media Player 11 installed, download and install it here,
Run Windows Update, and install all high priority and optional updates related to Windows Media Player or device synchronization.
On XP, the updates include:
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows Media Player 11 for Windows XP (KB939683)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Open Rhapsody
From 'My Account' menu select de-authorize computer
Close Rhapsody
To delete the mcs.rma file:
1. Close RealPlayer/Rhapsody
2. Click the Windows Start button. Then click Run.
3. Type %windir%\system32\ and click OK.
4. Find the mcs.rma file.
5. Right-click mcs.rma and select Delete.
6. Close the window.
To delete the basi3260.dll file:
1. Open the My Computer icon on your desktop.
2. Open the C: drive (usually Local Disk (C:\)).
3. Open the Program Files folder.
4. Open the Common Files folder.
5. Open the Real folder.
6. Open the Plugins folder.
7. Find the basi3260.dll file.
8. Right-click basi3260.dll and select Delete.
9. Close the window.
10. Restart your computer.
on sansa Clip itself, disconnected from computer, go to settings, then choose format
Make sure Rhapsody, Windows Media Player, and all other media programs are closed
download firmware (make sure you get 'Americas' firmware version)
unzip firmware file
connect to computer
drag firmware file onto sansa Clip icon in Windows explorer
wait to finish all copying (Sansa Clip screen will say connected, not writing or reading)
firmware updates on device, then it shuts off automatically
turn it back on
reformat from device (settings menu, format)
put in msc (under USB mode on settings menu)
open sansa Clip E:/ in Windows explorer, delete all files (should be 6-8 folders and files in top level directory of Clip)
reformat from windows explorer (right click, format, (FAT file system, NOT FAT32))
put in mtp (under USB mode on settings menu)
Open Rhapsody
It will run through quick setup again, due to files deleted before.
'Reathorize Computer' (under 'My Account' menu)
"Update Track Licenses' (same menu)
connect to computer
wait for Rhapsody to fully load clip (may take 30 seconds)
reformat from rhapsody (right click on sansa clip icon in rhapsody, select reformat)
hold down control and shift buttons at same time, right click on sansa clip icon in Rhapsody, select 'reset secure clock'
right click on sansa clip icon in rhapsody, select authorize device
wait while sansa clip updates (wait for screen of device to say 'connected' for a while, rather than writing or reading)
wait a while updates finish
verify acount, and dates on device, under setting menu, account
should say renewed (with today's date) expires a date 30 days later.
download one new track from rhapsody you never have downloaded before
transfer that one track to clip
wait for all updates to finish
verify account, dates on device, check that the track plays properly"
Hope that helps.
Feb 05, 2009 | SanDisk Sansa Clip MP3 Player
Removing stored music
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Jul 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa doesn't show any songs
Use Windows Media Player to delete songs. Click on the song name once and then press delete on your keyboard. Reformatting will erase all the songs, but don't reformat unless you are experiencing some issue or another.
May 24, 2008 | SanDisk Sansa e260 MP3 Player
have you deleted the partial video, if not......
1. connect the sansa to your computer,
2. select open device with windows explorer,
3. click on the drive where the video content is stored,
4. click on the video folder, then right click on and delete the video,
the path,
My Computer/Sansa e200/SELECTED DRIVE/video
May 05, 2008 | SanDisk Sansa e200 MP3 Player
Unable to delete a track
sir try to delete that by connectin ur player with pc..
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Below are the instructions. I hope I've made them clear enough!
Make sure your device is under MSC instead of MTP...To do that go under Menu, settings and then usb mode...
Step 1
Open up Windows Explorer: Start > Programs > Accessories > Windows Explorer
Step 2
On the right of Windows Explorer, click on My Computer
Step 3
You should see two devices after your CDROM drive. One will be SANSA E260R and the other will be Sansa e200R Rhapsody. Chose the one on the top; the one that doesn't say Rhapsody. It may say E250R, E260R, E270R, or E280R depending on which model you have.
Step 4
Once you're viewing the device, you'll see the folders: PHOTO and VIDEO. These are the folders that contain your photos and videos. For videos, you can simply remove the video you want to delete - it will completely remove it.
I hope that helps
Thank you
Apr 26, 2008 | SanDisk Sansa e250 MP3 Player
Deleting videos and photos
to delete videos u do the same thing as deleting pictures
Oct 29, 2007 | SanDisk Sansa e250 MP3 Player
I keep trying to delete songs but they still appear on my device.
Try connecting the device to the computer and using it as a Mass Storage Device and formatting/deleting from there.
Aug 17, 2007 | SanDisk Sansa e260 MP3 Player
Cant delete songs
reformat it. 1. right click on my computer and select manage. 2. go to disk management on the left panel. 3. right click on the sansa icon, and go to format. 4. make sure that the file system is under FAT32. This worked for me, hope it does for you.
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
142 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
