Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Changed new ink but when i print, the pages come out blank with no ink. Printing motion takes place but some how the ink done not reach the paper.
I had the same problem with my DCP 165.It simply wouldnt print.The paper was coming out but it was Blank.I had changed all the cartridges so there was no obvious issue with the ink.Then I printed a test page.It printed all the colour blocks except the black.Then i found out from Brother website that it was a problem with cleaning and after seeral cleaning cycles the printer worked fine. STEPS 1>ink management 2>Cleaning 3>Black or colour 4>OK Repeat the above process several times and try printing after that...Hope it works
Posted on Dec 05, 2010
No print only a blank page comes out
Wrong printer drivers for your computer or else they did not install properly. Also blank page may mean you are out of ink/toner.
Aug 19, 2014 | Office Equipment & Supplies
Printer sounds like it is printing but paper is blank when done
gabriel, have you tried to 1. clean and 2 allignment of cartridges using the tool function.?
Mar 24, 2014 | HP F4480 All-In-One Printer
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
My printer will not print anything on the paper when I press print or copy. However, it is going through the motions as though it is but the paper remains blank. I have replaced the ink cartidges &...
You are doing well, keep trying the ink as it is a new cartridge has to still come through.
Do a few more deep cleans and then print some test pages. You may need to do this a few times.
Thanks michellelwol
Take care!
damnor01
Apr 16, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Unit makes every noise and motion as if printing, but pages blank
First thing is if you haven't printed for while the ink may have dried in the print head. Run it through a few (lots) of print cycles and see if that starts to bring it back to life.
Check to make sure that you have the paper thickness set close enough.
My bet would be on the print head being clogged.
Apr 05, 2010 | Epson Stylus Color 740 InkJet Printer
Not printing
When a printer goes through the motions of printing bt delivers a blank paper, it is indicative of blocked nuzzles. Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 06, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
734 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
