Question about Avanti Microwave Ovens
I have invested in an Avanti Cafe Sleek Plunger and have had nothing but trouble with it!!!! Not only does hot water spurt from the sprout, but a horrible sludge is found in the bottom of our coffee cups! House, where I purchased it from will NOT give me a refund because it's been used. Okay, they have lost my business and goodwill for life. I would however like a full refund from Avanti - as a $10 plunger would have done a better job.
MicrowaveSvc
  • 9098 Answers
SOURCE: Amana Microwave model ACM1460AB
Weak heating is usually a bad magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
  • 2468 Answers
SOURCE: heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Posted on Apr 30, 2010
GodBlessU
  • 3513 Answers
SOURCE: My chefmate 12 cup coffee
You need to replace the bottom heating plate. You can easily find it in ebay . Its the braided rope like element which helps to make things warm.
Thanks
Posted on Oct 31, 2010
  • 5370 Answers
SOURCE: Sunbeam Cafe Series EM6900 Yesterday
Remove the black plastic thing from the filter basket.Check if that is cracked or broken.If its broken replace it,other wise remove it and clean it internally also clean the head gasket.:---It is held in by a little retaining clip. To get it out without damaging. Remove the spout (use a screwdriver wrapped with masking tape so you don't damage the spout...then use the screwdriver to leverage off the spout). Once you have the double or single spout off...get in there with a screw driver and pop it out! See fig below:-- helpmech_72.jpg its purpose is to insulate the pouring espresso from the portafilter, keeping it hotter. -------------
Remove the retaining clip for the basket with the tine of a table fork - easy!
- Remove the spout - you can use a screwdriver to loosen the double spout.
- A techscrew driver bit will be useful,It just needs to be something hard and cylindrical you can hit with a hammer to knock the plastic liner out. A bolt with an appropriate diameter would work fine.
- Placed the group head upside down on the carpet (to avoid scratching it on a hard surface) and give the driver bit a tap with a hammer whilst holding it against the bottom of the plastic liner.. It pops out with the tiniest of taps (and undamaged )
This is how dirty it gets/.Remove this and clean it and also check if its damaged:--See fig below:--
Try this cleaning and checking.This will help.Thanks.Keep updated.Helpmech.
Posted on Feb 11, 2011
  • 10865 Answers
SOURCE: working instructions not included would
hello lyn... go to this link http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1136
just below the picture of the machine, click on "manual pdf" and you will have a free download of the instructions you are seeking. Joe
Thanks for choosing Fixya!!
Posted on Mar 06, 2011
Mkb42b not hot enough
this sounds like your magnetron is starting to wearout
Mar 28, 2014 | AVANTI-SMALL APPLIANCES avanti mirror...
My ge cafe microwave has stopped working after hot oven was on
you are most likely correct . they were not made to withstand extreme heat from the outside
Sep 15, 2017 | GE CVM2072SMSS Microwave Oven
E4 error message
The E4 error code is a result of a malfunctioning defrost sensor. If the error code is on the right then it is the defrost sensor in the upper chamber.
Attached is a link to Avanti service and parts. Provide them with the model number of your wine cellar and they will be able to provide you with a price and information on the part needed for repair.
http://www.avantiproducts.com/index.php?page=contact
If you have the owner's manual or are able to speak with a service technician through Avanti, then this can be a diy repair.
Sep 06, 2013 | Avanti WCR5450DZ
I am getting power and the freezer appears to be working but the fridge is not cold at all, any suggestions? Many thanks Dave McRae
Hi Dave and welcome to FixYa, I am Kelly,
Take a look in the back of the freezer compartment. Look for any signs of icing on the back access cover. Usually but not always the evaporator coils freeze up because the unit is not automatically defrosting properly or there is a problem with the evaporator fan not running fast enough / at all. Press gently with your hand of the back cover of the freezer compartment and feel for ice. Also check the front of the chassis for signs of being HOT. It is ok to be warm not hot.
Also check to see that the light goes on and off as you actuate the light switch plunger. Some units have the door switch in the top of the door hinge but most have the switch in the door fold area of the chassis some where.
If you find that the evaporator coils have iced up:
  • Perform a manual defrost of the unit but first unplugging it
  • Remove the freezer contents
  • Direct an external fan into the freezer compartment for just over 2 hrs. (makes a water mess)
  • After 2 hrs clean up the water mess and return the unit to normal service.
  • Watch after 3 days if the fresh food compartment once again starts warming up. If it does you have and automatic defrosting problem.
No ice noted:
  • Possible temp control problem (Thermostat / cold control or thermistor)
  • Possible Air Damper problem. There are 2 kinds of air dampers. One is electrically controlled and the other is nothing but a mechanical baffle that is positioned partially open. If you have the electrical type the air damper motor may have failed or the movable baffle is stuck.
Front of chassis is almost HOT to the touch vs warm:
  • Open the back of the unit by removing the black fiberboard cover and inspect for lint and that the condenser fan is running anytime the compressor is running.
Light always on:
  • Door switch failure. Some door switches also control the evaporator fan along with water in door and ice in door functions. The water and ice in door should NOT work with the door open.
The above is pretty much an in home repair techicians check list for the symptom you describe.
If you discover that you have an automatic defrosting problem I will need you MAKE & MODEL number via your next response here so I can tell you what you can do to troubleshoot. (
Thanks for choosing FixYa,
Kelly
Feb 28, 2011 | Microwave Ovens
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
All of a sudden, the water is coming back up on my garbage disposal instead of going down, it also swirl. I tried to see if the blades are moving and they are free, not stuck, also there is nothing that I...
The drain out of the disposal is plugged up...
Take the drain piping apart and clean it out and then you will be good again...
heatman101
Aug 29, 2010 | Microwave Ovens
I recently bought an Avanti Stockholm Collection Multi Fondue set. It came with no instruction manual. I would like to have an instruction manual sent to me as i am unsure of the correct fuel to use.
i just baught an AVANTI multi fondue set and it came with the instructions but i lost them and was wondering if you are able to read instructions online
Aug 07, 2010 | Avanti Microwave Ovens
Avanti microwave. Panel not working, alot of beeping.
sounds like a panel issue for sure.
if the microwave is over 5 yrs old I would recommend replacing it
newer microwaves use far less power than before.
and they are not too expensive
May 27, 2009 | Avanti MO7180TW 700 Watts Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Avanti Microwave Ovens Experts
William Miller
William Miller
Are you an Avanti Microwave Oven Expert? Answer questions, earn points and help others
